Pocket GPS World :: View topic - Tom Tom Maps
Tom Tom Maps
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Retailers to buy from or avoid
Samsung
PostPosted: Wed May 07, 2008 3:15 pm    Post subject: Tom Tom Maps Reply with quote
Hi everyone,
Please can some one advise me where I can buy the latest Tom Tom maps from rather than downloading them from Tom Tom.
They will be for a Tom Tom 300 go.
thanks for reading
Redshift
PostPosted: Wed May 07, 2008 5:17 pm    Post subject: Reply with quote
You have no option other than downloading the new maps when purchased via the TomTom Home software on your PC. If you don't have a high speed internet connection you might be able to ask a relative or friend if they will let you use their PC - Mike
Samsung
PostPosted: Wed May 07, 2008 8:23 pm    Post subject: Tom Tom Maps Reply with quote
Hi Mike,
The original maps are on Tom Tom SD card that came with the Tom Tom and not downloaded.
I can probably down load them if necessary from Tom Tom but thought they might be cheaper from an online store.
If I do down load them from Tom Tom will they need a blank SD card ?
thanks
Malc
GerryC
PostPosted: Wed May 07, 2008 8:54 pm    Post subject: Reply with quote
Samsung, for a while now, the only way to upgrade the map has been via download. As this is done via a specific login to a specific device, it's to get around piracy problems that TomTom had more of before.
I would advise making a complete backup using Windows Explorer (see FAQ item 1) before doing any changes. With the price of SD cards nowadays, it would be better to use a new one if you can as the old one will still work as a backup.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
PostPosted: Wed May 07, 2008 8:56 pm    Post subject: Reply with quote
You would be best advised to purchase a new card of around 2GB in size, this way you can add any of the map options to your device (within reason). SD cards are cheap these days, a decent 2GB card shouldn't set you back any more than £15 and it leaves the original card intact should you ever need to recover the device from a disaster.
The original card will be very hard pushed to accept the newer applications and the newer maps, it is simply too small.
Purchase the new card, copy the entire contents of the old card to the PC using Windows Explorer, FAQ #8 explains how to do this from This Page.
Install the latest version of TomTom Home to the PC which can be obtained from Here, purchase your map and install it to the device.
If you have the old map and the new map on the new SD card don't forget to update the POI files and speed camera settings for the new map folder, also you will need to go to change preferences/ Manage Maps/ Switch Maps and select the new map in order for the device to use it.
When the new map is selected on the device configure your POI warnings as these are specific to the map file selected - Mke
RebelYell
PostPosted: Sat Jul 26, 2008 10:33 am    Post subject: Reply with quote
I tried this with my TT500. Aldi sell a 2gb card for £9.99. After transferring all the date from the orignal SD card to the new one the TT refused to recognise it and froze on me.
Dunno if it was the card or something I did? haven't tried since
PostPosted: Sat Jul 26, 2008 10:49 am    Post subject: Reply with quote
Have a look at FAQ #8 for details on transferring data to a new memory card, click Here, if it doesn't work after following that it is probably the new cards read speed, if it is too slow (which cheaper cards often are) the device will reject the card and refuse to boot up - Mike
RebelYell
PostPosted: Tue Jul 29, 2008 8:40 pm    Post subject: Reply with quote
Done that, thanks it worked. I was missin the hidden files.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Retailers to buy from or avoid All times are GMT + 1 Hour
