Pocket GPS World :: View topic - can you remove individual camera locations from Ov2's?
leesturbo
PostPosted: Sun Feb 17, 2008 1:09 pm    Post subject: can you remove individual camera locations from Ov2's? Reply with quote
i.e the camera's in your local area that you
know are there and are typically a niusance
for triggering alerts?
PostPosted: Sun Feb 17, 2008 1:14 pm    Post subject: Reply with quote
If you download POIEdit and install it to your PC you can open the ov2 file and remove the locations you don't want to trigger the device, bear in mind though you will have to do this every time you update the database for the unit.
As a tip it might help in future if you name the hardware you are using when asking questions of this nature, as it is not the usuall run of the mill kit you have IIRC - Mike
leesturbo
PostPosted: Sun Feb 17, 2008 1:26 pm    Post subject: Reply with quote
Cheers mike comments noted.
yes i'm using a gps performance meter
(Racelogic Performance meter)
for Poi triggering in the UK.
i can only use monochrome icon's too
so i had to individually change all the
poi bitmaps by opening into paint and saving
as M'chrome.
is the speedcamera ov2 info a range of co-ordinates?
as my unit triggers for 1000yrds before and after
a fixed positiom?
PostPosted: Sun Feb 17, 2008 1:30 pm    Post subject: Reply with quote
Lat/ Long plus ID, you can sort the data using POI Edit to make location of the local ones a little easier, give it a try although I wouldn't want to remove the locations from around where I live, there are hundreds of cameras in my local vicinity, it could take hours - Mike
leesturbo
PostPosted: Sun Feb 17, 2008 1:48 pm    Post subject: Reply with quote
Cheers mike,
the program works perfectly and i only needed
to ditch about 7 cameras in my immediate area.
Result.
Thx
PostPosted: Sun Feb 17, 2008 1:53 pm    Post subject: Reply with quote
That's an interesting device, I may have to approach the manufacturers for a review sample.
leesturbo
PostPosted: Sun Feb 17, 2008 1:57 pm    Post subject: Reply with quote
Hi Darren, a very highly reviewed and independantly
tested against extremely expensive and professional
equipment, results were very accurate.
huge range for testing lots of variables
