Pocket GPS World :: View topic - POI's and Igo Maps
POI's and Igo Maps
emma999
PostPosted: Fri Oct 26, 2007 10:44 am    Post subject: POI's and Igo Maps Reply with quote
Hi all,
I used to have a medion navigator with with medion navigator 5. I now have a mio p350 pda runnig igo maps. I was wondering can i make certain poi's like asda, etc show up on the map, as I drive so i can just see the sign??? At the moment I have to search for a poi, but I want it to show them al on the screen, can this be done, and if so how?
thanks
emma
Border_Collie
PostPosted: Fri Oct 26, 2007 2:55 pm    Post subject: Reply with quote
I can't find any built in Asda stores so you will need this http://inetcom.hu/mick/igo/ where you drag and drop the .cse file into the programme and it transfers to a new group in My POI. I would like to point out this programe is BETA and after experimenting with some POI's, which transfered OK, I couldn't get rid of them without a hard reset and re-install.
Start iGO, tap on Map, tap on Menu (top right), tap on Quick (bottom centre) Tap on Manage POI. Choose My POI then Asa and choose to Show or Hide POI's.
Remember, the more POI's you have showing on screen can slow down the refresh rate of the mapping.
emma999
PostPosted: Fri Oct 26, 2007 3:26 pm    Post subject: Reply with quote
cse file type???? some of the poi's i have are in xml format???
Im lost!!
emma999
PostPosted: Fri Oct 26, 2007 3:30 pm    Post subject: Reply with quote
what file type do my pois have to be to drag them into that software?
Border_Collie
PostPosted: Fri Oct 26, 2007 3:36 pm    Post subject: Reply with quote
Embarassed Sorry, typo, should have read .CSV file.
emma999
PostPosted: Fri Oct 26, 2007 3:40 pm    Post subject: Reply with quote
im gonna try it now, see if i can do it!
emma999
PostPosted: Fri Oct 26, 2007 3:43 pm    Post subject: Reply with quote
ok i added poi for all netto got this
-2.30984,53.59623,"[BL8 1] Wike Street [Bury]"
-2.49208,53.74936,"[Blackburn]"
-2.45335,53.56208,"[Bolton - St. Helens Rd]"
-3.21912,51.58388,"[Caerphilly] "
-2.62809,53.65844,"[Chorley] Water St"
-2.36619,53.47843,"[Eccles] Liverpool Rd"
-1.710844,53.83118,"[Greengates] New Line"
-1.669352,55.01358,"[Kingston Park] Kingston Park Ave"
-2.519421,53.49863,"[Leigh] St Marys Way"
-2.6965,53.69467,"[Leyland] Towngate"
-2.424466,53.5308,"[Little Hulton] Armitage Ave"
-2.19807,53.45686,"[M12 4] Stanley Grove [Manchester]"
-2.25472,53.50356,"[M7 4] Bevendon Square [Manchester]"
-2.25267,53.38815,"[Manchester Hollyhedge Rd]"
-2.14123,53.54494,"[OL9 9] Middleton Road [OLDHAM]"
-0.64139,53.59038,"[Scunthorpe] Tulip Rd"
-2.74183,52.70657,"[Shrewsbury] 16 Brook Rd"
-2.12104,53.34878,"[Stockport - Park Lane]"
-2.16601,53.41602,"[Stockport]"
-1.41695,53.7003,"[WF6 2] High Street [NORMANTON]"
-1.120453,53.30382,"[Worksop] Memorial Avenue"
-1.26564,52.37357,"009: -1.2656400,52.3735700"
-0.40875,51.44845,"POI-Warner (19.09.06 08:51:38 1200055469°/2023800952kmh"
-0.70166,52.48857,"POI-Warner (22.03.03 19:35:22 33°/0kmh"
DO I PASTE ALL THIS IN IGO/POI/SPEEDCAM FOLDER??? WHAT ABOUT THE PICTURE OF THE N FOR NETTO??? DO I DRAG THAT IN THERE AS WELL??
Border_Collie
PostPosted: Fri Oct 26, 2007 4:06 pm    Post subject: Reply with quote
Use the iGOPOIExplorer programme and drag and drop the file to the left hand window and using the programme you can transfer the folder to iGO.
Once done, go to Quick - Manage POI's - My POI, tap on your new Group once, Netto?, to highlight it, then tap on Edit (centre of screen) and select an appropriate icon. Arrow back (three times) and tap on Menu.
Tap on POI - My POI and you should see your new Group.
The built in iGO POI icons appear to be embedded in the programme and I can find no way of adding/changing them.
emma999
PostPosted: Fri Oct 26, 2007 4:22 pm    Post subject: Reply with quote
great thanks alot, yeah the icons do need changing really!!!!
Border_Collie
PostPosted: Fri Oct 26, 2007 4:33 pm    Post subject: Reply with quote
Just did a quick experiment.
Go HERE and go down to UK Asda, download and save the file to a folder in My Documents then unzip folder.
Start iGO POI Explorer and select File - Import POI's from file.
Navigate to where you saved the Asda folder - change 'files of type' from Google Earth KML to CSV POI file and you'll see the Asda file.
Drag and drop the Asda POI folder into the left hand window of iGO POI Explorer.
Left click, and hold, on the Asda folder and drag it over the iGO POI Database icon.
The file will then be transferred.
emma999
PostPosted: Fri Oct 26, 2007 4:58 pm    Post subject: Reply with quote
OK DONE THIS AM I STILL STUCK WITH THE ONLY ICONS IN THE IGOEXPLORER PROGRAM?
THEY ARE LIMITED AND NOT VERY GOOD
EMMA
Border_Collie
PostPosted: Fri Oct 26, 2007 5:07 pm    Post subject: Reply with quote
Yes, it seems so. I've looked in the various Data files and can find some icons, not the ones mentioned earlier, but the icons are in vertical strips, several on each, rather than being individual.
Is there any real need to have the Asda icons showing? I say this because you will still be able to set a route to one or add as a via.
emma999
PostPosted: Fri Oct 26, 2007 6:08 pm    Post subject: Reply with quote
good point, well again thanks for the help!!
I am set up and good to go!!
emma
PostPosted: Fri Oct 26, 2007 6:20 pm    Post subject: Reply with quote
Wouldn't the Asda File from HERE be more uptodate?
Border_Collie
PostPosted: Fri Oct 26, 2007 9:28 pm    Post subject: Reply with quote
Oh I see, I clicked on POI's rather than Download POI's.
Similar POI's so is there any need to keep the POI link now there is an updated version?
Ah good. At least you know how to add POI's and know where to look for others, in the Download POI link, NOT the POI one.
