Garmania Occasional Visitor
Posted: Fri Oct 20, 2006 11:53 am Post subject: To Get Proximity Alarm Warnings |
I have just successfully downloaded the camera database onto my Garmin Streetpilot c510. The cameras show up on the map as a red circle showing speed restrictions but I do not seem to have an option to switch on proximity alarms on my Garmin. Apparently the manual says this option only becomes available to switch on, once you have downloaded the Custom POIs which I have done, but in 'Sytems' my Garmin does not seem to recognise that these have been downloaded, so no Proximity Alarmis avalable to me.
Have I missed a trick here somewhere? |
Border_Collie Pocket GPS Verifier
![](modules/Forums/images/avatars/846718549526d5fd14b726.jpg)
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Oct 20, 2006 12:14 pm Post subject: |
Just a thought, but did you unzip the folder first and downloaded from the new folder to your Garmin? _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Fri Oct 20, 2006 1:44 pm Post subject: |
No I did not. I guess I need to get winzip to do that. |
Posted: Fri Oct 20, 2006 2:39 pm Post subject: |
If you are using Windows XP on the PC simply double click the downloaded folder and it will open. - Mike |
Posted: Fri Oct 20, 2006 3:41 pm Post subject: |
Thanks. Yes, I have been doing that. So I will have to ponder this some more! |
Posted: Fri Oct 20, 2006 4:21 pm Post subject: |
Which download have you tried to use with the device? You could also try downloading the database again incase the files have become corupted in some way - Mike |
Posted: Fri Oct 20, 2006 4:26 pm Post subject: |
With XP double click Zip folder, e.g. Oct10pgpsw-speed-cams.zip, to open it and then choose 'Extract all files', towards the top left, which will produce an unzipped folder named Oct10pgpsw-speed-cams. Use this one to install cameras to your device. _________________ Formerly known as Lost_Property
