Pocket GPS World :: View topic - 1 really stupid question re Sd card
Dilcymro
PostPosted: Tue Jun 27, 2006 6:56 pm    Post subject: 1 really stupid question re Sd card Reply with quote
Sorry about this chaps, I have recieved my 1gb viking SD card today and I hate to admit it, but I havent a clue which way to insert it ( the SD card that is ) on the side of it , it has a little yellow slider with lock on it, what is this for? and above the word viking there is an arrow pointing forwards. I`m afraid I have never used one before and am scared of shoving it in the wrong place.
Sorry again but any help appreciated.
Regards....Dil
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
portman
PostPosted: Tue Jun 27, 2006 7:22 pm    Post subject: Reply with quote
As you look at the i3 screen the transflash card contacts should be facing up and go in first, it clicks in to place. The transflash card slides inside the SD card but is only used for putting it in card readers or using it as a normal SD card.
http://www.valuemedia.co.uk/images/title_transflash_big.jpg
Dilcymro
PostPosted: Tue Jun 27, 2006 7:28 pm    Post subject: Reply with quote
Thanks portman, slight problem here, I`m putting it into the nuvi 310.
Cheers...Dil
Garmin Nuvi 2415
portman
PostPosted: Tue Jun 27, 2006 7:31 pm    Post subject: Reply with quote
Gone up in the world!!! I'm trying to resist the urge but I can't see me holding out much longer.
Dilcymro
PostPosted: Tue Jun 27, 2006 7:41 pm    Post subject: Reply with quote
Go on you know you want to Smile , best thing I have done in ages (well nearly )
It`s a brilliant piece of kit, bluetooth, larger screen which helps when your eyesight is failing as you get past your fiftieth, nice and slim fits in your pocket and also mp3 player, which is why I am trying to get this bl**dy Sd card in.
Garmin Nuvi 2415
PostPosted: Wed Jun 28, 2006 9:01 am    Post subject: Reply with quote
you can't put them in thewrong way. just push it in, if it goes all the way in then that's right, if not then flip it around! the 'cut offcorner' stops you putting it in the wrong way.
as for the slidy yellow bit, this basically write-protects the card, similar to the slidy bit on a floppy disk (if anyone remembers them!)
Dilcymro
PostPosted: Wed Jun 28, 2006 10:31 am    Post subject: Reply with quote
Thank you MaFt. Sorted.
Have also sent you a pm.
Thanks again....Dil
Garmin Nuvi 2415
22.055 (29 May 24)
