Pocket GPS World :: View topic - icn 520 speed cams
icn 520 speed cams
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds
inviroman
PostPosted: Mon Jun 26, 2006 8:47 pm    Post subject: icn 520 speed cams Reply with quote
Hi all
This is my first post just got a icn 520 and have put the speed cams on it is there a way for it to display a warning of the speed cam on the full display instead of at the bottom and can anyone recommend a good full 7 digit post code download?
alix776
PostPosted: Mon Jun 26, 2006 8:52 pm    Post subject: Reply with quote
here the how to for the 5 navman icn
http://www.pocketgpsworld.com//uksafetycameras-navman.php
device Lumia 950 xl
inviroman
PostPosted: Mon Jun 26, 2006 8:59 pm    Post subject: Reply with quote
thanks for the reply but that is not what i asked i have already put the speed cams on the icn by following the instructions which work fine but i want to know if a large icon can be displayed on the full screen instead of the just the text line at the bottom
Tim Buxton
PostPosted: Mon Jun 26, 2006 9:34 pm    Post subject: Reply with quote
No, it isn't possible.
Tim
inviroman
PostPosted: Tue Jun 27, 2006 1:12 pm    Post subject: Reply with quote
cheers
inviroman
PostPosted: Tue Jun 27, 2006 10:35 pm    Post subject: Reply with quote
can you install a new sound for the camera poi so instead of the dong can you have a voice for moblie /gatso/specs etc
also is it correct that you cant install the full speed cams list of 23 files so it shows the speed in the poi icn i have been told that you can have only 16 active poi's
captureboy
PostPosted: Thu Jun 29, 2006 6:59 pm    Post subject: Reply with quote
I was just about to post a question why I cant have more than 16 files in my POI. Thanks for the info, I'll have to download the speed cameras as files by camera type rather than by speeds.
mags
PostPosted: Sun Sep 03, 2006 12:30 am    Post subject: voice over the dong Reply with quote
I too would like to hear a vioce reminder that i am approaching a speed camara and not just a dong reminder
but from what I have read this is not possible
BlueNev
PostPosted: Fri Sep 07, 2007 9:48 pm    Post subject: Re: voice over the dong Reply with quote
Me too. I have got hold of a voice "Warning Speed camera ahead" as a .WAV file, and am going through all the .WAV files in the Windows (CE) diretory of the Navman to no avail... I did here the voice at startup as startup.wav is now the voice... but can't find the "BELL" sounds to alter them.
I suspect they are part of the UKFEM.dat file?
Anyone solved this elsewhere? ... going to look now
BlueNev
mostdom
PostPosted: Sat Sep 08, 2007 8:11 am    Post subject: Reply with quote
For the icn5** I recall seeing a post which explains that the only possablity to change the sound is to directly manipulate the file on the device.
Read this
And this
Dom
BlueNev
PostPosted: Sat Sep 08, 2007 10:06 pm    Post subject: Reply with quote
icn520 (not tried on others)
Eventually found ... the answer, in the depths of those links, thanks
like many others I probably need to have things spelled out...
In MYPOI folder there are the SPEEDCAM .map .bm .chk files and the following .ini file... with an extra line added, soundfile=, for with a .wav file held in the same directory.
[SPEEDCAM]
active=1
distance=200
time=0
visualWarning=1
soundWarning=1
soundfile=camera.wav
tere is no need to alter the currmap.ini file
I am going to play with the time=0 setting to see what happens.
Will also test the soundfile in am.
I will also try to add a number to the voice. I have .wavs for 30, 40 , 50 and 100!!!
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds All times are GMT + 1 Hour
23.092 (10 Sep 25)
