Schouten Regular Visitor
Joined: May 16, 2005 Posts: 86 Location: United Kingdom
Posted: Fri Jan 27, 2006 9:08 pm Post subject: ALK Respond |
Back on topic
This today from Sunil at ALK
Thank you for contacting CoPilot Technical Support.
Apologies for the delay in responding to your email. With regards to the POI timing, we are aware of this problem and currently working on a fix for this problem. A patch will be available to resolve this problem. We do not have an exact date for the patch but please check our website for further information regarding this. |
PONDEROUS Frequent Visitor
Joined: Aug 25, 2004 Posts: 634 Location: Lincolnshire, England
Posted: Fri Jan 27, 2006 9:41 pm Post subject: |
Eltel wrote:
Quote: | This today from Sunil at ALK |
It is good to see that ALK are apparently coming to appreciate the value of communication. It is a pity, though, that it comes over a month after 15th January, the date originally given for the patch - and some mention of that delay in Sunil's communication would have been helpful. Hopefully, it means that they are making sure that all the issues are addressed before putting the patch on the website. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
wayj Occasional Visitor
Joined: May 19, 2005 Posts: 8 Location: Stoke On Trent
Posted: Mon Jan 30, 2006 9:04 pm Post subject: copilot 6 |
Could any body please tell me if a review of copilot live 6 has been reviewed by GPSWorld? if so were is it.
I am thinking of upgrading from version 5 or changing to tom tom 5 and would appreciate any advice. |
Chorlie Regular Visitor
Joined: 30/07/2003 16:33:35 Posts: 92 Location: United Kingdom
Posted: Thu Mar 02, 2006 9:27 pm Post subject: |
Ok, Sorry I know this doesn't 100% belong in the thread, but having not got a reply in the Smartphone thread thought I'd ask in here.
I've installed, CoPilot Live 6 for Smartphoe onto my friends T-Mobile SDA II and all works fine, but I can't get the Speed Cameras to work, I've downloaded the single file version and installed as instructed, but there aren't any icon on the map & I don't get warned when passing any cameras.
I use the database with TTN5 and it works fine, anyone any ideas how to install it on to CoPilot 6?
Thanks _________________ Chorlie
If it isn't broken, play with it some more...
Posted: Fri Mar 03, 2006 9:16 pm Post subject: |
I think that the probem might be, Chorlie, that many of us haven't handled a Smartphone.
If it is anything like the Pocket PC version of CP 6, you will need to go into |Settings|Map and then check Enable for the POIs concerned. To get POI warnings, it is |Settings|POI Alerts and check all groups and sub-groups required. If that doesn't work (assuming the menus are similar) it presumably has to be your download. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Posted: Sat Mar 04, 2006 10:54 am Post subject: |
... assuming that the facility actually works on the Smartphone, that is... _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
