tcs17_tim Lifetime Member
Joined: 30/12/2002 21:41:31 Posts: 130 Location: United Kingdom
Posted: Sun Sep 14, 2003 8:04 am Post subject: ETA Algorithm |
Not that I can see, I was hoping someone on here might know how it works. |
Parky Regular Visitor
![](modules/Forums/images/avatars/avatar_ani_013.gif)
Joined: 25/05/2003 09:12:02 Posts: 247 Location: Bradford UK
Would I be correct in saying that once you have planned your route, it calculates your ETA on the type of roads you will be using. If so you could adjust the preferred speeds for these types of roads in properties, advanced, preferred speeds. Surely adjusting these speeds will make a difference in the ETA, because this calculation is done using this information. |
OOPS, Delete everything from my last post, I,m in the wrong forum. Though we were in TTN2.
Apologise's Guy's |
Anyone use the ETA feature? Anyone worked out how it works it out. It seems particularly pessimistic to me.
Does it assume 50mph average without taking into consideration the motorways it is telling you to drive on? |
BrianT Regular Visitor
![](modules/Forums/images/avatars/664252848440e146f2d04a.jpg)
Joined: 03/02/2003 14:17:44 Posts: 85 Location: near Geneva, Switzerland
I use it all the time and I agree, it does seem pessimistic but maybe that's reasonable on UK motorways! <g>. I do most of my driving in France and Switzerland. Is there a way of changing the speed defaults for the different types of roads? |
Telboy Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_003.gif)
Joined: 02/06/2003 22:43:11 Posts: 42 Location: Rickmansworth, United Kingdom
I used to use the ETA feature quite a lot, but since installing the Smart ST Pro SP1 it's no longer available. Does anybody know how to switch it back on?
Thanks. |
Tim Buxton Pocket GPS Moderator
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Telboy,
>> I used to use the ETA feature quite a lot, but since installing the Smart ST Pro SP1 it's no longer available. Does anybody know how to switch it back on? <<
It's only available when you have a route set, but if you look at the bottom of the screen, you'll have the 'Distance to next' reading in the bottom right corner, and in the bottom left you'll have another reading. This could be one of a number of things, say Speed, DTG, ETA, etc. Tapping the letters will change that reading and if you tap it enough times it will change to ETA.
_________________ Tim |
sfi1 Regular Visitor
Joined: 22/05/2003 09:37:02 Posts: 83 Location: United Kingdom
I seem to recall seeing on the navtech site that it's maps include max speed settings for roads so i'd guess it probably uses these in the calculation. |
Thanks Tim.
Terry |
I dont think they use the max speed for a road, the ETA is too pessimistic. |
