Pocket GPS World :: View topic - wrong speed limit
wrong speed limit
silverman
PostPosted: Wed Sep 14, 2005 10:31 am    Post subject: wrong speed limit Reply with quote
Realy getting to grips with my Go300. But one thing puzzles me. I have all the speed cameras loaded with voices,but when I pass one particular camera with a known speed limit of 40mph, my `Go` says Gatso 30mph. Is this a database problem ,or can I correct it?
Many Thanks
:P
Unplugged
PostPosted: Wed Sep 14, 2005 6:12 pm    Post subject: Reply with quote
Browse the Map and then click on the Speed Camera and if it has a speed associated with it it will say gatso:number@<speed limit>
If this is wrong then email the camera team who will update it for the end of the month.
rkm_hm
PostPosted: Wed Sep 14, 2005 8:20 pm    Post subject: Re: wrong speed limit Reply with quote
silverman wrote:
Assuming that you've assigned the correct voices to each speed category(!), you need to feed the correction back to the compilers - so that it gets corrected for everybody.
You can correct it yourself temporarily - but your update will get over-written with wrong data next month unless it has been corrected centrally.
If you want to correct it, you need to move the offending POI from the Gatso_30 * file to the Gatso_40 file. On a PC, you can do this by editing the .csv version, and then re-create the .ov2 files. On the GO itself, do the following - unless anyone knows of an easier way:
Browse the map and locate the cursor on the offending Gatso.
Create a POI at the cursor position, and store it in the Gatso_40 category.
Then use the menu to delete POI, and find and delete the one in the Gatso_30 category.
* Unless you've changed the file names, the full name is much longer - beginning with PocketGPSWorld - but it should be obvious which files I am talking about.
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
silverman
PostPosted: Thu Sep 15, 2005 9:09 am    Post subject: Incorrect gatso speed Reply with quote
Thanks for your help guys.
This is a grat site. :P
22.055 (29 May 24)
