walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 491 Location: South Yorkshire
Posted: Tue Dec 20, 2016 1:54 pm Post subject: |
yeh, it shouldn't be a problem (i never had the issues with the older garmins)
is it still the same regarding the smartlink app, that if you use this it will override the traffic information on the unit itself or has this been resolved |
Kremmen Pocket GPS Verifier
Posted: Tue Dec 20, 2016 4:08 pm Post subject: |
The last time I tested Smartlink traffic using my test rig, and my old work route that used to go horribly wrong, it worked perfectly, and very quickly. The bar was populated yellow and red in seconds.
I only did it a few times, and from my armchair under gps simulation mode, so a very limited test.
What has happened since my switch from Smartlink to cable is that the Smartlink app has been updated twice. Maybe they sorted it. _________________ Satnav:
Car Average MPG :
Posted: Tue Dec 20, 2016 10:55 pm Post subject: |
well gone ahead and bought it for xmas, it can't be any worse than the tomtom that decides when it wants to use the features it supposed to have - all wrapped up waiting for me to open it from santa on xmas day |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Wed Dec 21, 2016 2:15 am Post subject: |
Nice _________________ Where there's a will ... there's a way. |
Posted: Wed Dec 21, 2016 6:34 am Post subject: |
I suppose this means you want my source code again to tweak it for your needs
It has changed quite considerably since you had it last. _________________ Satnav:
Car Average MPG :
Posted: Wed Dec 21, 2016 5:36 pm Post subject: |
Cheers Kremmen,
Not at the moment you seem to be doing a good job of it - hope you kept the code nice and tidy
I've got so much on and never have the time and been doing nothing but sql coding at work so been learning that -
i'm still trying to get all my photographs sorted from this year and just not had the chance |
Posted: Wed Dec 21, 2016 6:43 pm Post subject: |
Some bits of it could be tidier but I wanted to keep it self contained.
I've gone back to a data file because each new install under Microsoft ClickOnce goes to a different UserData folder and ID so the built in 'mySettings' is useless under those new installs.
I did some Transact SQL. Different but powerful. _________________ Satnav:
Car Average MPG :
Posted: Tue Dec 27, 2016 11:07 pm Post subject: |
off back home tomorrow, so thought would setup the device ready
tried getting it to locate my address and won;t find it, can't seem to also get it to search via postcode.
even if change search location and take it down to the village, it's still a no go
so how do you perform a postcode search on the unit or get it to locate an address as even trying my inlaws address it still says cannot find search results
fixed it: had to deselect and reselect the maps and now can search on postcode |
BAVC10 Lifetime Member
Posted: Tue Dec 27, 2016 11:55 pm Post subject: |
Tap 'where to' at then you should have an enter Town or enter postcode option to the right. If you can't find the Postcode make sure you have the right country selected as this can throw a few funnies such as Newport in Bucks rather than Newport, Gwent rather than showing both together plus many tens of other options for that town _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
Posted: Wed Dec 28, 2016 12:42 am Post subject: |
when i went into change search near and choose address it reported 'no map data available' but maps were ticked euopre 2016.30 so unticked and reticked which fixed problem. |
Posted: Wed Dec 28, 2016 6:40 am Post subject: |
I've never had that but they do prefer to be fully rebooted after any update, assuming it didn't come with 2017.03 pre-installed. _________________ Satnav:
Car Average MPG :
Posted: Wed Dec 28, 2016 7:56 pm Post subject: |
no it came with 2016.30 installed - and not updated yet - hopefully later tonight or tomorrow will update it and then start looking at getting the PGPSW cameras on it
worked well on it's first run - quickly rerouted - notifications were spot on - notified me of upcoming delays - forgot how different it was to the TT in respect of this - but still got the nice clear interface |
Posted: Thu Dec 29, 2016 6:20 am Post subject: |
Is the Driveluxe voice commands the same as the Driveassist I had for a day.
On the DA you had to pre program it with 'your voice' speaking numbers one to nine.
Then all the commands were in a menu system so when you said say, two, that menu popped up with further numbered commands.
As I said previously, on the DA it refused to accept my 'three' and 'five' because it reckoned they were too close to my 'two' and 'four'. No matter how slow or how close I was it failed.
I even tried the military trick of speaking 'fife' instead of 'five' but it was having none of it. _________________ Satnav:
Car Average MPG :
M8TJT The Other Tired Old Man
Posted: Thu Dec 29, 2016 9:30 am Post subject: |
Presumably, in addition to it not recognising your numbers, you have to also look at the device to find what menu item you want to select? So you might as well just reach out and tap the screen. |
Posted: Thu Dec 29, 2016 9:41 am Post subject: |
You can, but if your dash is as far away as mine then voice control is the way to go. Also, with the latest glass screens fingerprints are an issue. _________________ Satnav:
Car Average MPG :
