sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Thu Aug 01, 2013 6:58 am Post subject: |
I'm confused. No nuvi I've heard of comes with a card already installed, maybe you got a refurbished unit? Also if you had 3.01 Gb free at the start of the map update process it should have ample room for the new map, as the old one is deleted.
Ignore the language text reminder, things like that occur on some nuvis with the updater not realising you've already applied the update.
Back to the maps. To see what is installed you need to do two things to reveal the hidden .system folder which is where they reside. Set Explorer to show hidden AND system files:
and set your nuvi to mass storage and not mtp mode:
1. Start NUVI by itself and go to Volume Screen.
2. Press the upper right hand corner of screen for 10 seconds.
3. The Developers Screen will pop up
4. Scroll down to MTP SETTINGS
5. Change from AUTO DETECT to MASS STORAGE
6. Shut down NUVI and connect to PC
7. It should now connect in mass storage mode.
As an alternative to step 1 above, you can bring up the Nuvi's "dashboard" screen, then press and hold the speedometer for about 10 seconds to access the developer screen.
Once you can see what's in .system post back with the map files there and what's on the card (the .img files and any associated .unl and .gma files) |
jonstatt Regular Visitor
Posted: Thu Aug 01, 2013 9:20 am Post subject: |
Firstly, thank you so much for your advice and help.
It doesn't seem like a refurbished unit in the sense that it is immaculate with no fingermarks (original sticker on screen) or packaging disturbed (only one serial number sticker on the box). On the Halfords UK website, a person reviewing the item they bought also commented that there was a 4GB micro SD card in their 3598. Nevertheless I was a bit surprised to see it there. My unit actually says 3598 on the sticker on the back of the unit, unlike many who have found it says 3597.
I used the tip you gave to connect in mass storage mode and I could see the 3D map component was still on the main device even though I had installed the main maps on the memory card. I removed the 3D map which meant there was 3.7GB free but still even the GarminMapUpdater said there wasn't enough space and that I needed 3.1GB (which of course makes no sense at all).
So then, having installed the maps on the memory card...I tried to copy the main map and 3D map onto the internal storage by drag and drop. It doesn't fit! This is partly related to the GUPDATE.GCD file. So I removed that and it fits with only 47MB left. If I try to reinstall the maps, it says there isn't enough space again. This is far too tight. When I first got the unit it said it had 200MB free. Then after the first batch of non map related updates this dropped to 100MB. SID folder is 984MB, ASR folder is 1.02GB and JCV folder is 447MB. Total storage capacity is 7.02GB
If you look at the size of the main European file it is now absolutely massive. I think they have started to put the 4GB cards in the units because they know these new European maps won't fit otherwise!
Posted: Thu Aug 01, 2013 9:41 am Post subject: |
That's the correct size for the full EU map. I only use a partial reload on mine, and just install Western Europe ... you might consider that?
The other option is to delete all the EULA, voice, text, vehicle and keyboard files that you don't want/need to help free up space.
Failing that I guess you're stuck with the sd card. |
Posted: Thu Aug 01, 2013 9:51 am Post subject: |
sussamb wrote: | That's the correct size for the full EU map. I only use a partial reload on mine, and just install Western Europe ... you might consider that?
Thanks. So am I right to understand that all purchasers in Europe of the a 3597 or 3598 that didn't get a SD card bundled with it, would have had a shock when 2014.10 came out and that "by default" it wouldn't fit?
Interestingly the express updater wouldn't even let me install Western Europe but GarminMapUpdater will. |
Posted: Thu Aug 01, 2013 9:57 am Post subject: |
I guess so. Maybe Garmin are indeed shipping them with sd cards now in recognition of that. To change map coverage in Express it's here:
Posted: Thu Aug 01, 2013 10:17 am Post subject: |
Thanks. But Garmin Express won't let me install Western Europe. It is greyed out due to filesize. See the screenshot where you can see some lines are grey and some are black.
However GarminMapUpdater WILL let me install Western Europe. Sounds like the Express version is wrongly calculating free space
Posted: Thu Aug 01, 2013 10:24 am Post subject: |
Strange ... but then Express is still a bit of a 'work in progress'
I continue to use MapUpdater |
Posted: Thu Aug 01, 2013 12:54 pm Post subject: |
sussamb wrote: | Strange ... but then Express is still a bit of a 'work in progress'
It gets weirder. I deleted all the downloaded maps on the PC, removed the 3D and main European img files off the 3598. Then I ran GarminMapUpdater, and it installed the whole European map! And now I have 140MB left spare on the main memory, where I couldn't even fit things in before doing a file copy. The IMG files are all the same size as previously.
I know where some of the space has come back....the smaller JCV file has disappeared (Express installs a large one and a small one, whereas mapupdater only installs the large one). But that only explains a bit of the returned space.
I am now wondering what is missing!! |
Posted: Thu Aug 01, 2013 1:23 pm Post subject: |
Run WebUpdater ... that should replace any 'missing' files. |
Posted: Thu Aug 01, 2013 4:23 pm Post subject: |
sussamb wrote: | Run WebUpdater ... that should replace any 'missing' files. |
Oddly nothing appears to be missing. I do not know where that space magically came from. When the GarminMapUpdater was running, it was brutal and wiped directories and recreated them. Maybe there was some file hanging around in limbo...I don't know.
Either way, I will get on and drive at this point and see if everything appears to perform well. I wish I had known about the MTS mounting trick from the start and done a complete binary back-up of the original files. |
Posted: Thu Aug 01, 2013 4:26 pm Post subject: |
Quite possibly ... I suspect all will be well. Enjoy your new toy
(PS Worth backing it up now) |
Posted: Thu Aug 01, 2013 6:27 pm Post subject: |
sussamb wrote: | Quite possibly ... I suspect all will be well. Enjoy your new toy
Thanks again for the help.
I was playing around with the smartphone link software. I was curious about the PhotoLive camera option where you get to see real traffic images from cameras across the UK. But the smartphone link is offering me every subscription except this one. I see 3D traffic, parking, weather and speed cameras.....but the PhotoLive option isn't there! According to Garmin's website it should be. |
Posted: Thu Aug 01, 2013 7:37 pm Post subject: |
No idea about that one ... you may need to contact Garmin Customer Support unless someone else here can chime in and help. |
Posted: Fri Aug 02, 2013 1:40 pm Post subject: |
I called Garmin. I was pleased to find it went through to a UK call center. They tried it there and found it was missing. They emailed me very quickly afterwards to say the PhotoLive service has been withdrawn temporarily due to problems with the coverage (only London is working at the moment). Once the motorway cameras are working again they will reintroduce it..... (no ETA) |
Posted: Sat Aug 03, 2013 12:21 pm Post subject: |
So I had my first couple of journeys with my 3598. On the whole I was impressed but I had a couple of catastrophic issues where the map suddenly became all grey except for the turn arrow. All the menus and other screens are absolutely fine when this happens, so it doesn't seem to be a hardware issue. It's like it had problems loading some of the map at that moment in time. I have seen another reference on the forums to this issue. I had to pull to the side of the road and power it off and on again and then it would display correctly again. It happened twice..... If it keeps doing this it will have to go back unfortunately. |
