PiaggioMP3 Occasional Visitor
M8TJT The Other Tired Old Man
Posted: Fri Feb 15, 2013 9:36 pm Post subject: Re: New Nissan COnnect with V1.5 firmware |
PiaggioMP3 wrote: | but would it be possible to create an update file with NO cameras in, thereby making the Nissan Connect system empty as far as cameras are concerned? Or did I miss the point? | Why would you want to do that? Or am I missing the point?
PS can you copy the relevant bit of the manual here. The damn Chrome popup on the site that yuou linked to is peeing me off Apart from the fact that it didn't download for me. Now for a virus check. |
Posted: Fri Feb 15, 2013 10:08 pm Post subject: Re: New Nissan COnnect with V1.5 firmware |
M8TJT wrote: | PiaggioMP3 wrote: | but would it be possible to create an update file with NO cameras in, thereby making the Nissan Connect system empty as far as cameras are concerned? Or did I miss the point? | Why would you want to do that? Or am I missing the point?
The point is, if you load the PocketGPS cameras you get two warnings, one from PGPS and one from Nissan, with the Nissan ones being out of date so false warnings as well.
The Manual is 18 pages (pdf). The upload site is MEGA and is protected by PGP (pretty good privacy) so that anything on there cannot be seen, this may be causing you an issue. They are virus free files, as I only uploaded them a short time ago. I will try and find other links. |
Posted: Fri Feb 15, 2013 11:04 pm Post subject: Re: New Nissan COnnect with V1.5 firmware |
PiaggioMP3 wrote: | The point is, if you load the PocketGPS cameras you get two warnings, one from PGPS and one from Nissan | My confusion arose because you missed that little bit of info from your first post. |
Andy_P Pocket GPS Moderator
Posted: Fri Feb 15, 2013 11:09 pm Post subject: |
Can't you just switch off the TT-supplied camera warnings on the Connect?
You can on all the normal TomTom models. _________________ "Settling in nicely" ;-) |
Posted: Fri Feb 15, 2013 11:25 pm Post subject: Re: New Nissan COnnect with V1.5 firmware |
M8TJT wrote: | PiaggioMP3 wrote: | The point is, if you load the PocketGPS cameras you get two warnings, one from PGPS and one from Nissan | My confusion arose because you missed that little bit of info from your first post. |
Soz, thought it was obvious. |
Posted: Fri Feb 15, 2013 11:29 pm Post subject: |
Andy_P wrote: | Can't you just switch off the TT-supplied camera warnings on the Connect?
You can on all the normal TomTom models. |
Nissan Connect is not TomTom; if you turn off warnings it turms them off for in-built and add-on POI's
Anyway, back to the original thought - a new camera update purchased form Nissan will DELETE French cameras (now against the law in France to have these), so it is entirely possible to delete them all! But then Nissan wouldnt get any update income. Think the only way to fix it is to somehow edit their update file so all cameras are disabled. |
Posted: Sat Feb 16, 2013 10:15 am Post subject: |
OK . Nothing is obvious to me unless it's spelled out letter by letter , Do you have a copy of the Nissan cam database offering. If so, can you open it in Notepad or similar to see the format? If so, just try deleting the contents (on a copy of course) and see what happens. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15143 Location: Bradford, West Yorkshire
Posted: Sat Feb 16, 2013 10:53 am Post subject: |
M8TJT wrote: | Do you have a copy of the Nissan cam database offering. If so, can you open it in Notepad or similar to see the format? If so, just try deleting the contents (on a copy of course) and see what happens. |
it's built into the firmware... |
Posted: Sat Feb 16, 2013 11:38 am Post subject: |
Doh. Repeat to myself 100 times. "I must read posts and try to twig that if it's built into the firmware you can't overwrite it".
Makes you wonder how often they would get updated though, doesn't it. |
