Pocket GPS World :: View topic - North America and Europe updates 2013.10 on Garmin 670T
Road_Runner
PostPosted: Wed Jun 06, 2012 12:07 pm    Post subject: North America and Europe updates 2013.10 on Garmin 670T Reply with quote
So the North America update ran first, for some reason. Then when it came to Europe the updater says there isn't enough room. Ideally I'd like to have the Europe map on the unit, as I'm more likely to go there at the moment. Several questions come to mind, in no particular order:
Can I re-install the North America map onto an SD card, for use if I go there?
What size of SD card do I need?
Does a map on an SD card access as fast as from main memory?
Do I then delete the NA map from the unit, if so how do I do that?
Can I then load the Europe map to the unit, and will there be enough room?
Is there any mileage out of deleting junk from the unit's memory, like the 'Help' files in various languages?
If anyone has any experience of any of this, or any advice (e.g. factory reset then start again?) I'd be truly grateful; I've had the 670 for five years nearly and it does all I want. I'm trying to avoid having to lash out on a newer machine as I don't do that much travelling.
S/W version 4.90
Memory 4.12GB
(Available: 56.9MB following NA map update)
