Newsletter
Pocket GPS World :: View topic - IOI and other Text Tab delimited files
donie
PostPosted: Thu Dec 09, 2010 4:40 pm    Post subject: IOI and other Text Tab delimited files Reply with quote
Hi there,
Messing around with the new features in Ver1.50 (and some existing ones I had not tried previously) and the different types of files you can download via the Sat Sync application. No problem with .png format icons. Just starting on the IOI option and not having success yet. Sat Sync reports it fails to transfer the file. Wondering if anyone else has had success converting Excel Vista to Text Tab delimited files and downloading to an Active 10.
Does anyone know how much text we can add in here?
Donal
Gibbo10
PostPosted: Thu Dec 09, 2010 9:21 pm    Post subject: Reply with quote
Make sure the excel file is closed before you action the transfer.
Don't think there is a limit on the text.
Satmap A10. Platform 09.02.21, Software version 1.50 Satsync 1.50
GSAK / Quo Mapping
Geocacher ID The K9 Crew
My Blog Geocache Trails
Gibbo10
PostPosted: Thu Dec 09, 2010 9:50 pm    Post subject: Reply with quote
After just testing the .txt file import I've found that there is a bug.
Although column G for the image is optional it appears to fail the import if it is left blank. A work around is just to type anything in the column then save as a tab delimited file (close the excel file) then import it. After the import you will get a message saying that some pictures didn't import but the rest of the text will be okay.
I'll report it to satmap.
GSAK / Quo Mapping
donie
PostPosted: Fri Dec 10, 2010 9:49 am    Post subject: Reply with quote
Reported to Satmap.
Donal
donie
PostPosted: Fri Dec 10, 2010 4:38 pm    Post subject: Reply with quote
.. and had a response within 10 minutes.
Now that is service from the Techie guys. I will try it over the weekend and let you know if its sorted.
Donal
donie
PostPosted: Mon Dec 13, 2010 12:23 pm    Post subject: Reply with quote
Have the import working correctly thanks to the Satmap techies. Sorry for taking so long to reply, but I had a great weekends walking. Even has a cloud inversion over here and walking in glorious sunshine above the clouds. Even managed a Glocken Spectre. The upshoot is the new Ver 1.5 sun filter works a treat.
The advice from Satmap is to contact them directly if you require this fix if importing OOIs only via tab text files.
Donal
Gibbo10
PostPosted: Mon Dec 13, 2010 9:15 pm    Post subject: Reply with quote
If you connect your satmap today it will automatically upgrade with this fix. Word of warning though satsync seemed to get into a loop and keep telling me there was a new version of satsync available. In the end I clicked remind me later
GSAK / Quo Mapping
donie
PostPosted: Tue Dec 14, 2010 8:44 am    Post subject: Reply with quote
Hi Gibbo10,
Exactly the same response myself.
Nice to see the fast response in upgrading SatSync, its reassuring.
11.062 (12 Jun 13)
