Pocket GPS World :: View topic - voice alerts (IGO 2006)
snowyjp
PostPosted: Sat Dec 19, 2009 12:08 am    Post subject: voice alerts (IGO 2006) Reply with quote
Hello
can any one tell me how to down load Aus/Nz consolidated sound file to my iGO unit
snowyjp
PostPosted: Sat Dec 19, 2009 2:48 am    Post subject: Re: voice alerts Reply with quote
snowyjp wrote:
Hello
Is there such a thing? I don't know of any sound files for any of the camera databases except for the UK and Europe.
Can you say where you've seen it?
I'm not sure if voice alerts work on the iGo either....
As M8TJT said after sorting out your camera problems in your other topic
Well Snowy, that's a result then. I told you not to give up Very Happy
I don't think Igo have ever done voice warnings for speedcams Sad .
PostPosted: Sat Dec 19, 2009 9:46 am    Post subject: Reply with quote
Speed cam voice alerts do not come with a standard IGO installation. Sad You have to load and enable a skin (Display interface) that supports them and the voice files themselves. Try Googling for IGO 1006 skins. Installing them is a bit more difficult than the PGPSW database. I know what your problem is, you are fed up with the 'turkey gobble' alert. The default sound mentioned abov is 'Alert5' which you could edit or load a different sound as Alert5 to quieten it down a bit. Very Happy
Dont forget to make a full Windows backup of your device or SD card before you start.
snowyjp
PostPosted: Sun Dec 20, 2009 7:23 am    Post subject: Voice alerts Reply with quote
Hello again wow my mind bogles
I think to much for this 70yo brain
I have got all the voice files in wav format
they are in the uk locations
is it possible to convert these files to aus so they activate at my speed camera locations
Its a thought
Snowyjp
PostPosted: Sun Dec 20, 2009 7:30 pm    Post subject: Re: Voice alerts Reply with quote
snowyjp wrote:
Hello
Not quite certain what you mean by 'Aus/Nz consolidated sound file'
and also
snowyjp wrote:
I have got all the voice files in wav format they are in the uk locations
It is not possible to just put the voice files on the IGO and have it work. You also HAVE to put a 'Skin' that supports voice files onto it as well to use them. I suspect that you will need someone who is realy a PC black belt to help you do this. Confused
snowyjp
PostPosted: Sun Dec 20, 2009 8:54 pm    Post subject: voice alerts Reply with quote
OK mate
i will have to put up with just the beeps
maybe there is voice files on the net somewhere
Have a great xmas
you have been great
Regards
Snowyjp
snowyjp
PostPosted: Tue Dec 22, 2009 11:27 pm    Post subject: voice alerts Reply with quote
hello again
i now have a skin for voice files it is Ultra Skin v2.6
i down loaded it direct to iGO folder but when i tried to open the GPS i got a message Error( ffui error) so i had to delete it and go back to factory settings
do u have any ideas how to install it i have not got any instructions
the sound files have an ogg ext
snowy
PostPosted: Wed Dec 23, 2009 9:01 am    Post subject: Reply with quote
It is probable that the skin that you have tried is not for IGO 2006. I believe that linknet's Ultra skin is for the latest versions of IGO. It won't work with IGO 2006. You need a skin that has been designed for 2006. Try Googling for igo 2006 skins, but I don't think it will be easy to find one, unless linknet is lurking and knows the answer. Linknet's latest skin for IGO 8.3 does not support voice alerts anyway. Sad
snowyjp
PostPosted: Fri Jan 01, 2010 11:38 am    Post subject: voice alerts Reply with quote
HI mate
I found a skin that supports iGO2006
The prob is i cannot find the skin folder in the content so i made a new folder and downloaded the skin there but did not work is there a way to open the skin folder that is in the menu
also i need to have the correct resolutions but cant find how to change them
can u help me there
Snowy
PostPosted: Fri Jan 01, 2010 4:46 pm    Post subject: Reply with quote
As I said before, I am not familliar with 2006, Confused but in IGO8 there is a menu item Menu ~ Settings ~ {More. Right arrow} ~ Menu ~ Skin. From where you can select the skin. If not then I hope that a 2006 expert will junp in and suggest a way of doing it. Very Happy
22.051 (01 May 24)
