Pocket GPS World :: View topic - TT Go 510/710 Reset
TT Go 510/710 Reset
Phil-the-Fluter
PostPosted: Thu Jul 30, 2009 1:52 pm    Post subject: TT Go 510/710 Reset Reply with quote
I'm having trouble with my unit. Everytime I press the on button, all I get is the tomtom two hand sign and the sound clip that goes with it, then it closes down after 10 seconds. This happens everytime. Having read the instruction book, there is nothing about the reset. Does anyone know how long to hold down the reset and do you do it in conjunction with anything else?
pcaouolte
PostPosted: Thu Jul 30, 2009 6:35 pm    Post subject: Reply with quote
I don't think it matters how long you hold down the reset button but some people say that there are two types of reset, one a short poke and the other holding the reset button down for 30 seconds. Why not try both.
If you are getting the drum roll sound then the reset is probably working.
Can you access the data on your tomtom when you connect it to a computer?
Paul
Oldboy
PostPosted: Thu Jul 30, 2009 7:25 pm    Post subject: Reply with quote
On the x10 series the Reset is a pin-in-the-hole job on the underside of the Unit.
Having said that the drum roll usually indicates that the unit has reset.
With the unit off, try taking the SD Card out, then re-insert it. Switch the unit on.
Phil-the-Fluter
PostPosted: Fri Jul 31, 2009 2:14 pm    Post subject: Tried and tried Reply with quote
Thank you both for your suggestions. I've tried every combination of holding start, not holding start, short spike reset, long hold reset. I keep getting the two hands and the drum roll then it closes down. Tried taking the SD card out and putting it back, probably tried things that even their R&D guys haven't thought of. No joy. looks like I'm heading towards my wallet for the first time in 2 long years.
Thanks again.
Crying or Very sad
pcaouolte
PostPosted: Fri Jul 31, 2009 6:01 pm    Post subject: Reply with quote
Don't give up yet!
Do you have a card reader for your PC? If so can you see any data on the tomtom card.
If not can the PC see the data on the tomtom card when the tomtom is connected to the PC?
Paul
Phil-the-Fluter
PostPosted: Mon Aug 03, 2009 8:56 am    Post subject: Reply with quote
I used my PDa to see if there was anything on the SD, it all appeared to be there. But I'm not sure if there was anything missing so thats all I know.
pcaouolte
PostPosted: Mon Aug 03, 2009 5:46 pm    Post subject: Reply with quote
Do you have a backup of the data from your SD card on your PC? If so you could try copying the data to a new SD card and posting back here with the result.
Paul
22.044 (24 Apr 24)
