Pocket GPS World :: View topic - TomTom Traffic on Go 530 using Tytn II ?
DBLogic
PostPosted: Sun Jun 21, 2009 7:16 pm    Post subject: TomTom Traffic on Go 530 using Tytn II ? Reply with quote
Just bought a 530 as an upgrade to my old Mio 168 and so far have managed to upgrade it to the latest application (8.351), map and PGPS speed camera with only slight problems (all solved thanks to postings on the forum Smile )
I have succesfuly connected my phone (O2 branded Tytn II) to the 530 for both voice and data. I've tested this using the weather service and also the qgps update. Am I safe in assuming that GRPS Traffic will now work if I take out a subscription ?
The reason I ask is that the Tytn II doesn't show as being compatible with TT Services but other posts seem to suggest it might wok but need the WM6 DUN. I would add that I'm running WM6.1 and haven't installed the DUN cab but the data connection seems to be working.
thanks for any help.
DBLogic
PostPosted: Sun Jun 21, 2009 7:24 pm    Post subject: Reply with quote
If the Weather service is working OK then the other GPRS based services will function fine, seems strange your Tytn has the Dun profile working though, or have you added a cooked ROM to the device as that might have contained the necessary code for this to work - Welcome to the forum by the way - Mike
DBLogic
PostPosted: Sun Jun 21, 2009 8:10 pm    Post subject: Reply with quote
No standard O2 ROM.
Just after posting though I found it wouldn't make a data connection. tried the original version (8.014) on a SD card and it connected fine. Rebooting on the internal disk then worked!
Just rebooted both phone and 530 and noticed though that data failed initially from the 530 but worked after I'd triggered a data connection on the phone by getting my emails. I suspect that I do need the DUN intsalling so that the 530 can trigger a conection if one isn't on although I'm not sure if the internet connection sharing feature might not also do the same thing if enabled. More testing needed I think Confused
The good news is though that I should be OK to take out a traffic subscription Smile
PostPosted: Sun Jun 21, 2009 8:19 pm    Post subject: Reply with quote
Do you have the DUN CAB file? if not I can e-mail it over if you want? - Mike
DBLogic
PostPosted: Mon Jun 22, 2009 2:43 pm    Post subject: Reply with quote
Thanks Mike but I've got a copy from a link on another post.
I've checked the actual files and registry entries that the DUN CAB installs and only one of the files (bthatci.dll) is on there and only reg entries for this can be found so I'm pretty certain t hasn't been installed.
I've just tried restarting both devices (using the pin in hole method) and TT Weather and Screen colour Downloads both worked first time. It took a few seconds (20 maybe) for the first "Connecting to server" to work but after that it seemed quite fast.
Guess the next step is to put my hand in my pocket and take out the subscription for Traffic.
Many thanks for your help.
DBLogic
PostPosted: Mon Jun 22, 2009 7:19 pm    Post subject: Reply with quote
Update:
Just subscribed to Traffic and all working perfectly. Very Happy
PostPosted: Mon Jun 22, 2009 7:30 pm    Post subject: Reply with quote
A "Resolute" solution then, and for under £50 - Mike,
DBLogic
PostPosted: Tue Jun 23, 2009 9:40 am    Post subject: Reply with quote
Very good Mike Very Happy
(if memory serves me correctly it's actually Sir Edward Elgar but better known as Hercules when I first saw it in the 70's Smile )
22.052 (08 May 24)
