Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Wed Jun 17, 2009 10:47 pm Post subject: |
Hi Folks
There is one thing that I learned from this Forum yonks ago and that was to keep away from ‘Home’ when ever possible. As far as I am concerned its for downloading maps and nothing else. I get a fix very quickly without any help from ‘Home’ and when I think back to the days when I first had a PDA running Tomtom 3 I marvel at the current fix time. _________________ Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2143 Location: Surrounded by A1, M1 & M25
Posted: Thu Jun 18, 2009 7:35 am Post subject: |
On the X40 range it appears that it will bypass Home and download the QuickGPS fix itself via its inbuilt mobile and there appears to be no settings to control this. I thought it was a manual update function in the unit but it seemed to have done it on its own when I was recently away on holiday and had no access to Home. _________________ Drivelux |
layingback Regular Visitor
Posted: Thu Jun 18, 2009 11:50 am Post subject: |
quickfix - or equivalent - should help you get a quicker fix in either (or both) of the following situations:
- you've moved the unit a big distance with it powered off, so that it can no longer find the satellites where it is going to initially look for them, which is where it thought it left them (basic rule of thumb is 100 miles);
- unit has been powered off (asleep) so long that the satellites have moved (can't remember the period, but a few days won't be a problem).
Otherwise it will just look for the satellites where it last saw them, and if it can find at least 2 within the range it's looking at it'll be away.
Obviously the above assumes a 360 degree clear view of the horizon, and performance degrades as that drops, but not as badly as one might initially assume, 'cos way more than the 3 needed for a fix are visible horizon to horizon. _________________ Go Premium X / Go 1005 |
DennisN Tired Old Man
Posted: Thu Jun 18, 2009 7:32 pm Post subject: |
layingback wrote: | quickfix - or equivalent - should help you get a quicker fix in either (or both) of the following situations:
- you've moved the unit a big distance with it powered off, so that it can no longer find the satellites where it is going to initially look for them, which is where it thought it left them (basic rule of thumb is 100 miles) |
I popped my GO into my bag and flew to Corfu with it switched off. Switched on a few hours later, quite prepared to wait a long time to get a fix - so I gave myself a fix by uncapping an Amstel. The GO had a lock by the time I got back out on the balcony. _________________ Dennis
Two of them are obesiting!! |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Thu Jun 18, 2009 8:36 pm Post subject: |
Yeah, but if your fridge was on Crete ...... _________________ David |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Thu Jun 18, 2009 8:41 pm Post subject: |
..... or back at home in your kitchen ........... |
Posted: Thu Jun 18, 2009 9:14 pm Post subject: |
I can't win can I? I make my first serious post this month and promptly some bloke from out west and some bloke from up north both jump on it and give it a ridiculing.
My fridge is right here behind the swivel chair in my computer room. _________________ Dennis
Andy_P Pocket GPS Moderator
Posted: Thu Jun 18, 2009 9:58 pm Post subject: |
There's a couple of widely-held misconceptions rearing their heads again here....
Firstly, no sat-nav can "find the satellites where it is going to initially look for them" as it only has a single not-very-directional aerial and is a passive receiver.
It actually just receives data from the various satellites saying where THEY thought they were at a particular time (the ephemeris and almanac data), and the sat-nav number-crunches that to work out it's position by a sort of triangulation (more correctly - "trilateration").
Secondly, if you powered off the sat-nav for ANY time the satellites most certainly WOULD have moved! They are not geo-stationary, they are whizzing round at about 8,300 miles an hour, making two orbits a day.
What methods like Quickfix do is allow the unit to use published ephemeris data, before it has had time to collect the real thing from the satellites.
Quote: | While the ephemeris data is transmitted every 30 seconds, the information itself may be up to two hours old. If a fast Time To First Fix (TTFF) is needed, it is possible to upload a valid ephemeris to a receiver, and in addition to setting the time, a position fix can be obtained in under ten seconds. It is feasible to put such ephemeris data on the web so it can be loaded into mobile GPS devices. |
LOTS more info (more then you could ever want!) on Wikipaedia HERE |
DrRobin Occasional Visitor
Posted: Mon Jun 22, 2009 10:53 am Post subject: GPS Problems |
I appear to have encountered a similar problem but with a Binatone T430. I hadn't used the unit for a couple of weeks and when I did, it would find satellites but wouldn't compute a position. I assumed that it had lost it's almanac, which it should refresh from the satellite, but can take some time.
I left the unit on over-night in a position with a clear view of the sky. The next morning it had a position and now finds it's position very quickly even after a full shut down. I do however, have a problem with GPS time, it is reading year 18203 and some of the times aren't valid (E.g. hour 37).
I spoke to Binatone nd they told me that updates to the GPS system are causing problems with some receivers and they told me this started last week. These problems include loss of position and time and problems calculating position. I am a little sceptical of what they told me so decided to check it out for myself and there may be some truth in it, see link below:
http://sidt.gpsworld.com/gpssidt/Latest+News/New-GPS-Satellites-Problems-Indicated/ArticleStandard/Article/detail/596465
Apparently not all GPS chipsets suffer the problem and the only real issue appears to be when the GPS looses it's almanac (switched off or low battery for a long period of time) but it is very annoying.
I asked if there would be a fix for the GPS receiver if this turns out to be a permanent problem but they guy I spoke to wouldn't comment.
I have just compared this with another GPS receiver, which shows almost exactly the same position but displays the correct time. The chipset in the T430 is MStar.
I am bit worried that the unit packs up altogether and if there is no fix then I am left with a duff unit.
Regards
DrRobin |
Posted: Mon Jun 22, 2009 1:34 pm Post subject: MStar chip set |
Apparently there has been a change to the NEMA output from the satellites and the MStar chipset doesn't correctly decode this.
MStar have apparently released a patch which fixes the problem but in most cases you need to get this patch from the manufacturer's of the Sat Nav.
If the MStar chip has correct time apparently it doesn't output any position at all. If like me I have managed to dump the almanac then it will output correct position data but the time flips every second.
My T430 is flipping between 27/1/18216 and 1/1/1601. I am asking Binatone for a patch.
I simply don't know how many other devices use the MStar chip set, worth a check in the specs if your Sat Nav isn't working.
Regards
DrRobin |
george57l Regular Visitor
Posted: Tue Jun 23, 2009 10:00 pm Post subject: |
My better half came home tonight complaining her TT One stopped getting a satellite signal today while she was out. It has never been updated, changed, connected to TT Home or otherwise altered in any way from out-of-the-box. I've had this from time to time with my TT 500 and it usually recovers after a while or a reset.
Have reset the TT One (despite it not having a reset hole - apparently one has to press the power button for 30 secs) and it still sees no sats.
Anyone any ideas? Purely coincidental? (Re the last comments re Mstar?) |
