Posted: Fri May 15, 2009 8:02 pm Post subject:
I think my own method for rolling a device back to a previous version is slightly easier than messing around getting Home to do something such as this:
mikealder wrote:
I assume you are wanting to take the 730T back to Navcore 8,302
To install this to your device I use WinRar which you can download from Here Switch the TomTom on and connect it to your PC, if TomTom Home starts up exit the application as Home isn't needed for this.
Double click the downloaded file
Depending upon which one you downloaded and winrar will fire up, use the mouse to select all files and folders then click "Extract To"
Please note the screen images I have used for this post are from an earlier version of TomTom Navcore, but the process is the same if installing any Navcore to the device.
Locate the drive letter associated with your TomTom and click it, make sure the Overwrite mode is selected to "Ask before overwrite", then press "OK"
When the dialogue box pops up saying "Confirm File Replace" click the "Yes To All" button.
Sit back and watch the progress bar, with a good USB2 connection a Navcore 8,302 installation will take around 2 minutes.
When its finished the update use the "Safely Remove Hardware" icon from the Task Tray and remove the lead from the device.
Let the device boot up and tap the sat strength meter (lower left) followed by the version box, the resultant screen will confirm the version installed is Navcore 8,302 - Mike
Posted: Fri May 15, 2009 8:47 pm Post subject:
dhn wrote:
I thought that ever since you mugged your son-in-law to get the 700 back, you threw all your other units out the window. Was I wrong?
Gosh, you have to be joking David! It's difficult enough coping with only three on the windscreen - I have Wayfinder on my Sony Ericsson C702 so I have to find out how to work that to get more comfy in my travels. _________________ Dennis
OK, took the plunge and decided to upgrade to this new version. Installation according to Home went fine, now the unit refuses to boot up! Just sits on the boot screen for about a minute then reboots itself and continues to follow this pattern.
Any suggestions before I revert back to the previous version?
They deliberately reduced the volume? My wife is very hard of hearing - not completely deaf, but she needs the volume that we have now! So to get the new map when it comes out, which I've paid for, she's going to have to struggle more to hear? When I replace our 920, what's the best in the competition?
Doug _________________ Doug Weller
Doug's Skeptical Archaeology site:
http://www.ramtops.co.uk
I have 8.350 on the internal memory of my 720, and generally am pretty satisfied with it. I thought it might be a good idea to have 8.302 on my SDHC card in case I had any problems, so I used Mike's method above to extract 8.302 onto the card. When I put the card into the device, sure enough it booted up in 8.302 and appeared to route OK, but the sound did not work. Checked that all the settings were ok, and they were. None of the voices worked, TTC or recorded. Took the card out and it worked fine in 8.350.
All I had on the card was the 8.302 application installed from Mike's link. That still managed to read the map from the internal memory, but should I have put anything else on the card?
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Joined: Apr 07, 2006 Posts: 249 Location: Kent , England
Posted: Sat May 16, 2009 10:32 am Post subject:
I too had the volume problem when I upgraded to 8.350 and I have got to say it was a pain in the ar#e working yesterday.
Not so bothered hearing the voice commands , it was the speed camera warnings that I like to hear.
But having read this thread I unticked the noise level box and I think that everything is back as it was.
The proof of the pudding will be at work on Monday. _________________ Keith
TomTom GO 730T App 8.392 (1909/091109) , W and CE 2GB v835.2419
Posted: Sat May 16, 2009 10:52 am Post subject:
Put a voices folder in the root of the SD card and copy a couple of recorded voice files into the voices folder, see if that offers the non TTS voices, assuming it does work you can then copy some of the contents of the LoquendoTTS folder from the device to the LoquendoTTS folder on the card.
The 8,350 update will have changed a couple of files in the LoquendoTTS folder, so getting this part working can be tricky but its entirely possible to do. Have a look in the LoquendoTTS folder on the SD CARD and you will find two folders:
/bin
/lib
In each of these folders is a single file which is created/ updated by the installation of the Navcore, these files must remain in place and should not be replaced with the newer ones from the LoquendoTTS folder on the device which is Navcore 8,350 All the other files and folders can be copied over to the memory card to make a fully functional TTS voice setup on the card. Note on a fully working TTS system there is far more than just one file in each of the /bin and /lib sub folders.
To be honest I think the easiest way to do this is copy the entire LoquendoTTS folder from the device Flash memory to the SD card then re-install the Navcore 8,302 to the card, this will then put the correct files in the correct folders and it should work - Mike
Joined: Feb 14, 2006 Posts: 53 Location: Aberbargoed S.Wales
Posted: Sat May 16, 2009 12:08 pm Post subject:
Just took the plunge and updated my GO 720 to 3.50. It all went without a hitch, volume level was a bit lower but un selected the "link to noise" box set it at 95%, its now loud enough and no distortion. The TT still finds its satellites and rds signal as fast as it always did.
Camera voices are also at a good level.
One thing i noticed that i didn't before is at the top right where the box shows an arrow in the direction of the next turn and distance. if there is another turning just before the one you need to take, the screen changes to show the arrow, and the extra turn instead of the distance.
This happened when about 200 yds from the turning.
I might have missed this before but don't think so.
All in all I am quite happy with the update. _________________ Regards Mike
Posted: Sat May 16, 2009 4:07 pm Post subject:
Let's make sure I have got this right.
First, copy the LoquendoTTS Folder from the internal flash memory to the card
Then extract Navcore 8.302 to the card (presumably overwriting the LoquendoTTS I have just put there)
BTW, when I went through the Voices menu options, they were all there. I just couldn't make them work!
Satmap Active 10
Posted: Sat May 16, 2009 4:13 pm Post subject:
Robin2, what you have described is how I would approach this, by putting the LoquendoTTS folder on the card first when you use WinRar to extract the Navcore to the card it will only replace the two files within the /bin and /lib sub folders during the installation, everything else will remain as before - Then it should work - Mike
Joined: Nov 02, 2004 Posts: 111 Location: North Wales
Posted: Sat May 16, 2009 4:16 pm Post subject:
I gave my updated 920T (software on device, maps on card) a 4.5 hour trip back from Cambridge yesterday. The suttering has gone, and the volume on Kate was fine. However the volume on the PGPSW camera warnings is significantly lower than before! _________________ LG G4, Google Nexus 9, Garmin Oregon 600T
Posted: Sat May 16, 2009 5:19 pm Post subject:
Thanks Mike - that fixed it. I hadn't realised how loud (and distorted!) Kate was on max volume, as I only bought the refurb 720 just a week or so ago and went straight to 8.350 85% seems ok.
On the brief test I have just done, there was no trace of Kate stuttering. Was that fixed by 8.302?
Satmap Active 10
Posted: Sat May 16, 2009 5:34 pm Post subject:
Not 100% but it was considerably better than 8,300 - interesting your comments about the volume with Kate set at 100% when comparing the two software versions, I guess you are one of the few people that have an idea why TomTom decided to lower the output level if you can clearly hear distortion - Just remember though if/ when the next maps are released you will have to be running 8,350 to get the new map working on the device - Mike
Done nearly 150 miles since Thursday with update still not noticed any problems voice could be a bit louder but if I take the tick out of link to noise Kate blasts out instructions.
Have noticed that when playing music it does stutter the last word before instruction given but thats minor.
Shadow under car icon nice touch.
Fingers crossed I'll stay happy _________________ TomTom Go 950 Live.
App 9.054
Europe v8.50
NA 2GB v8.45
