itaylort Occasional Visitor
Posted: Tue Feb 10, 2009 10:18 pm Post subject: 540 completely locked up on start screen |
Hi all
I hope someone can help me with the 540. It has completely locked up on the start up bridge screen and will not turn off.
i have tried holding down the on button. Also tried putting it on the dock.
I cant see any reset holes like the 530.
Any ideas?
Ian |
Posted: Tue Feb 10, 2009 10:21 pm Post subject: |
Press and hold the power on/ off switch until the device reboots and plays a drum roll, typically 30 to 40 seconds, this is how you reset the newer devices - Mike |
Posted: Tue Feb 10, 2009 10:23 pm Post subject: |
I htink i have sorted it, needed to hold the button down for 25 secs not fifteen as the book says |
Posted: Tue Feb 10, 2009 10:37 pm Post subject: |
Do your x40s play the drum roll? Mine doesn't / never has! Is there a setting for this?
ETA: I mean on every start up? |
Posted: Tue Feb 10, 2009 10:44 pm Post subject: |
Mine did after i had just reset it, but it doesnt now.
Ian |
Posted: Tue Feb 10, 2009 10:55 pm Post subject: |
You only get a drum roll following a reboot, restarting after a connection to the PC, removal/ insertion of a memory card or holding down the power switch are all ways to get the drum roll - normal power on will not produce the noise - Mike |
Andy_P Pocket GPS Moderator
Posted: Tue Feb 10, 2009 11:04 pm Post subject: |
mikealder wrote: | You only get a drum roll following a reboot, restarting after a connection to the PC..... |
I DON'T get a drum roll after disconnecting from the PC, never have done. No idea how or why it is different to a complete reboot - the progress bar goes across the bottom of the screen in the same way. |
Posted: Tue Feb 10, 2009 11:08 pm Post subject: |
Quote: | You only get a drum roll following a reboot, |
Such as after updating NavCore? If so, that's a no.
Quote: | restarting after a connection to the PC, |
Such as after selecting Disconnect Device in TT Home? Yellow screen with blue line going left to right? If so, that's a no.
Quote: | removal/ insertion of a memory card |
Just tried it. Nope.....
Quote: | holding down the power switch |
Not tried it...... yet |
Posted: Tue Feb 10, 2009 11:19 pm Post subject: |
To be honest, I'm thinking of previous experience, mainly with a 720, Maybe I've never heard it on the 940 in the other situations.
But it (the 940) DOES on a reboot from a long power button press (I just did it). |
Posted: Tue Feb 10, 2009 11:23 pm Post subject: |
Yup. Reboot made it do the drums thing....
So at least something works ok.... |
