theripper Pocket GPS Verifier
Joined: Feb 07, 2006 Posts: 581 Location: Medway Towns, Kent
Posted: Tue Apr 21, 2009 10:23 pm Post subject: Reporting Errors to TomTom |
I have noticed that my 520 with map UK & ROI version 825 will not route me correctly onto the A2 from the South Circular Road in SE London. Instead of turning right onto the A2 it takes me further up the A205 then does a uturn and turns left onto the A2. I have checked the turn restrictions and blocked roads but they are ok. So what is the best way to report this to TT as it is not really a map error. |
falkirk81 Pocket GPS Verifier
Joined: Jul 07, 2006 Posts: 1649 Location: Newcastle, England, UK
Posted: Tue Apr 21, 2009 10:34 pm Post subject: |
There are two ways.
1. Using mapshare, if no category exists for a report, then there is a 'other error' feature i believe.
2. Using the teleatlas website, http://mapinsight.teleatlas.com/mapfeedback/index.php allows you to report errors directly to teleatlas/ tomtom! _________________ Tomtom GO 1005 LIVE
iPhone 12 |
Posted: Wed Apr 22, 2009 1:33 pm Post subject: |
Thanks for the reply but they are still for map errors and in this case there are no map errors it seems to be a program error |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Wed Apr 22, 2009 1:46 pm Post subject: |
You can still log it as an "Other Error" as this gives you the opportunity to enter some descriptive text to detail exactly what the error is.
Alternatively, log a support incident with TT and let them decide how to deal with it. _________________ Garmin DriveSmart 50 LMT-D |
Andy_P Pocket GPS Moderator
Posted: Wed Apr 22, 2009 1:49 pm Post subject: |
It could be a map error - having the wrong speed attributed to a small section of road. |
Posted: Wed Apr 22, 2009 4:23 pm Post subject: |
Andy_p
It is a major junction from one main road(South Circular) onto another(A2 to Dover) controlled by a set of traffic lights. As you approach the junction it tells you to get in the right hand lane, but then does not tell you to turn right but go straight throught the lights, do a u-turn and then turn left onto the A2. I hav checked the turn restrictions and they show that you can turn right at this junction and none of the roads are shown as blocked, therefore as far as I can make out it must be a program error. You can try it with the following -
Prepare route
Address
Street & House
Eltham
Legatt Road
to-
Address
Street & House
Bexleyheath
Bean Road
You will then see what I mean.
theripper |
Posted: Thu Apr 23, 2009 12:43 am Post subject: |
I've just had a look (this is on the v825 W+CEurope map) and agree that it tells you to go straight on and do a U-turn.
But looking at the turn restrictions on my map it DOES ban right turns here. See picture:
Is that different on your UK map?
I don't know the junction so I won't change the restrictions myself. |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Thu Apr 23, 2009 9:33 am Post subject: |
It's the same on Google maps, so doesn't appear to be a TT routing error. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
Posted: Thu Apr 23, 2009 1:22 pm Post subject: |
Andy_P wrote: | I've just had a look (this is on the v825 W+CEurope map) and agree that it tells you to go straight on and do a U-turn.
I dont know how to do a screenshot on my 520 but on my map the right turn and the u-turn are both allowed but it wont route it. Had a look at someones 720 this morning with WE 825 and his is the same as mine.
If you use mapshare you could change both of them as they are both allowed.
More to the point is why two maps of the same revision numbers are different.
theripper |
Posted: Thu Apr 23, 2009 2:00 pm Post subject: |
Screen capture is easy, check your e-mail - Mike |
Posted: Thu Apr 23, 2009 3:07 pm Post subject: |
thanks to Mike I can now use a screenshot
This is the same on UK & ROI and WE 825. I drive home this way every weekday when I am on duty and have done for the past 12 years driving from the bottom of the screen then turning right onto the A2 which although it shows no restrictions TT will not route me that way.
theripper |
Posted: Fri Apr 24, 2009 1:17 am Post subject: |
theripper wrote: |
More to the point is why two maps of the same revision numbers are different. |
That will happen once Mapshare corrections start being made.
Unless something has changed very recently, Mapshare corrections are specific to each region map. In other words if you] start with a brand new v825 UK map and I start with a brand new v825 Europe map they both will be the same, but any Mapshare corrections you make will ONLY be downloaded to other UK map users, I will never see them.
Similarly, any Europe map corrections are only sent to Europe map users.
What that doesn't explain is why the altered turns are still not being used on your system. |
Posted: Fri Apr 24, 2009 8:45 am Post subject: |
I have already tried using my virgin map and its exactly the same, likewise the bloke at work with the 720 does not use mapshare.
theripper |
Posted: Fri Apr 24, 2009 11:12 am Post subject: |
As I suggested earlier, log it as a Support Incident. TomTom may be able to tell you what is wrong, and if they can find the solution, submit it internally as a MapShare correction.
They did this for me some time ago when I asked them about the infamouus M40 J15 problem. _________________ Garmin DriveSmart 50 LMT-D |
Posted: Wed May 06, 2009 6:00 pm Post subject: |
I havejust spoken to CS and after updating to Navcore 8.350 this junction showed up as a no right turn so I have now corrected it. So it must have been a navcore problem |
