Pocket GPS World :: View topic - All Frozen Up - Help Please.....
Goto page Previous  1, 2
fatchef
PostPosted: Thu Mar 27, 2008 8:30 pm    Post subject: Reply with quote
Hi All, apologise for taking so long to get back with an update! Anyway, I went to their HQ (Mon 17 Mar) and stormed in with my frozen active 10 that was only hours old.
Richard explained that they had an issue with 1 line of programming (out of the new 30 thousands + lines) in ver 1.15 – the error would make the system freeze if “location” was chosen as the display for any of the data boxes (the 2 or 4 Data Box Layout that the user has the option of changing)! Obviously I’d changed one of these whilst playing around. They had the fix there already (hot from the programmers that morning) so I got it updated there & then (ver 1.16). He added that they found out late on Sunday at the outdoor show, he was obviously gutted after doing all the updates and new sales at the show – “…..run before you can walk….. springs to mind!
All seems to be fine now apart from I’m finding satsync to be a little “hit or miss” – It always says file added blar blar… but doesn’t always show on the unit…?
Jason
PostPosted: Thu Mar 27, 2008 9:50 pm    Post subject: Reply with quote
Thanks for posting this information as I was wondering what the issue was that prompted the v1,16 release, that said, other than messing around "learning" the device I cannot really see much use for a data box showing current position when it is clearly shown on the map! - and lat/ long data is only a few button presses to access anyway - at least your device is sorted out though that is the main thing - Mike
fatchef
PostPosted: Thu Mar 27, 2008 11:22 pm    Post subject: Reply with quote
mikealder wrote:
......other than messing around "learning" the device I cannot really see much use for a data box showing current position when it is clearly shown on the map! ...... - Mike
Exactly Mike! I also think there's another post somewhere quoting Richard as saying "that the majority of users will not notice the fault", obviously for the reason you state above!
I blame the tiny joystick verses my fat fingers - surely i didn't mean to select that option! Shocked
Jason
PreshawPete
PostPosted: Sat May 24, 2008 7:58 pm    Post subject: System Locking mid-route Reply with quote
I'm a new user and quite impressed so far but am repeatedly bothered by the system freezing and having to reboot. It's often an hour or more into a trip. Very irritating!
Any ideas?
robs1972
PostPosted: Sat May 24, 2008 8:56 pm    Post subject: Re: System Locking mid-route Reply with quote
Any ideas?
Mentioned on another thread is a firmware update that cures freezing....we shall see.
I like mapping, I like mapping, I like mapping and I like to map!
super_claret
PostPosted: Sun May 25, 2008 8:07 pm    Post subject: Reply with quote
After using my SatMap many times without problems I've suddenly started having 'freezing' issues.
I charged my lipol overnight, it was showing full charge in the morning, I achieved sat lock as I put my boots on, then, when I changed to the routes menu, it froze. I took the battery out and re-started the unit, went through the same procedure, activated the route and set off on my 19 mile route. 3 miles into the route, I woke the unit up and it was frozen again. I took the battery out and re-activated the route, re-set the trip log and off I went again, this time I completed the route without any further problems.
I'm really disappointed about having spent all that money on a unit that doesn't work properly and any confidence I had in the unit, prior to the freezing issues, has disappeared. A shame really, as the unit promises a lot.
Mark
LostMike
PostPosted: Mon May 26, 2008 4:20 pm    Post subject: Reply with quote
Its my understanding that the new software upgrade (that some have already received) and we all should get in a few weeks is supposed to solve this problem. You might like to ring SatMap and see if they think it will solve yours.
Or you can try deleting any unnecessary routes stored on your A10. I found that as a accrued routes on my machine it began to slow and lock. Having tidied it up things now seem fine.
Hope that helps
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
super_claret
PostPosted: Mon May 26, 2008 6:56 pm    Post subject: Reply with quote
LostMike
I only have 2 routes on the internal memory!
I wondered if it might be the length of the route that may be the problem. Would it make a difference if I copied my route to the SD card rather than the internal memory?
It's annoying and spoiling what would otherwise be an excellent product.
Mark
LostMike
PostPosted: Mon May 26, 2008 8:44 pm    Post subject: Reply with quote
I don't know, but if you do not want to delete them or ask SatMap about the beta software then it is worth a try. But don't forget to delete them from the internal memory once you have copied them to the SD card.
LostMike
Satsync 1.525
super_claret
PostPosted: Sun Jun 01, 2008 12:34 pm    Post subject: Reply with quote
Mine is freezing regularly now, whether it be out following a route or messing
with the unit in the house. I was scrolling through the 1:50000 North of England mapping to find a location this morning when the unit locked up on me. This is becoming very frustrating to the point of wanting to return the unit for a refund. I've emailed SatMap about it and will wait for their reply, but I am very disappointed, as this is a fantastic bit of kit when it's working OK.
Mark
Page 2 of 2
22.052 (08 May 24)
