Pocket GPS World :: View topic - Problems with lock on the B2
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems
a17esh
PostPosted: Fri Jul 28, 2006 12:00 pm    Post subject: Problems with lock on the B2 Reply with quote
Thought id shre this with you guys with problems!
I had a problem with my B2 locking, it was the cradle not holding the b2 in properly as it looses the tight fitting after awhile:
Cure - rubber band, did the job for a bit to hold the B2 down in place. It needs to be pushed down on the right hand side!
But also, teh back of the b2 you have a square retangle where the crade sits onto, Add some electrical tape to it, i needed about 3-5 layers, it should then slot onto the cradle and fit tight. Does this make sence - does to me. maywork for some of you i hope![/img]
DenzB
PostPosted: Sun Jan 21, 2007 2:43 pm    Post subject: Reply with quote
Thanks for the info, my B2 is now doing the same.
Keeps reseting as if its loose on the cradle.
Will try your advise and see how its goes
Thanks DenzB
Fraserp
PostPosted: Fri Mar 23, 2007 5:38 am    Post subject: Reply with quote
DenzB
I had the same, spoke to Origin, they replaced the magnets FOC and the problem was resolved.
Fraserp
TomTom 1000
GPSmap 60CSx
SatMap
DenzB
PostPosted: Fri Jul 13, 2007 4:44 pm    Post subject: Reply with quote
Thanx for the info and sorry for the delay with my reply.
Sent unit back to Origin for repair under warranty, seems to work Ok now.
fingers crossed
DenzB Smile
JamesJamz
PostPosted: Sat Feb 16, 2008 11:36 pm    Post subject: Reply with quote
Im also having a problem with my unit ATM... When the laser is activated, the unit keeps resetting itself for some reason...
Anyone else come across this?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems All times are GMT + 1 Hour
22.053 (15 May 24)
