Pocket GPS World :: View topic - uptodate speed camera download help
hardtail
PostPosted: Sun Sep 03, 2006 1:38 pm    Post subject: uptodate speed camera download help Reply with quote
hi there i wonder if you can help i have a tom tom one and stupily brought a disc off ebay with the camera database and cameras on , ive installed them both and they work fine but was wondering about the updates , i no if i subscibe i can download them butwhat do you do then just copy and paste the lot in to the great briton map folder or do i have to delete all the existing ones
PostPosted: Sun Sep 03, 2006 1:58 pm    Post subject: Reply with quote
The new ones should simply replace the old ones IF they are carrying the same file name, if not then you might be as well to delete the old ones.
If you need/ want to delete the old files simply look in the Map folder for any files with the extension on .ov2 and remove them, then put the new files on the card in the map folder.
Next setup your "Warn when near POI" for each camera.
I would also recomend you copy the entire contents of the card to your PC just in case you delete a file incorrectly - without a back-up you could cause even more harm - Mike
22.055 (29 May 24)
