jackb Occasional Visitor
Posted: Thu Feb 02, 2006 1:18 pm Post subject: rechargeable battery's |
any one know if its ok to use rechargeable battery's on my streetpilot i3
Thanks jackb |
Beerbellybill999 Regular Visitor
Posted: Thu Feb 02, 2006 1:47 pm Post subject: |
yes fine, but make sure they are high power ie Ni MH 2100 or above _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed) |
Alang Occasional Visitor
Posted: Thu Feb 02, 2006 2:16 pm Post subject: |
Also change your setting -> System -> Battery Type -> NiMH.
Alang |
alan_t Regular Visitor
Posted: Fri Feb 03, 2006 12:07 am Post subject: |
so what difference does it make in the settings to choose one battery type or the other? |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Fri Feb 03, 2006 1:28 am Post subject: |
alan_t wrote: | so what difference does it make in the settings to choose one battery type or the other? |
The rechargable batteries have a lower voltage so it uses this setting to try to determine how much power remains in the battery. If you put 1.5v Alkaline batteries in the unit and tell it you have 1.2v NiMH batteries then it will show the alkaline batteries as having more power.
Likewise if you put NiMH batteries in there and tell it you have alkalines then it will think they are low on power when they aren't (they just have a lower voltage output) _________________ Gone fishing! |
Posted: Fri Feb 03, 2006 2:14 am Post subject: |
Skippy wrote: | alan_t wrote: | so what difference does it make in the settings to choose one battery type or the other? |
Likewise if you put NiMH batteries in there and tell it you have alkalines then it will think they are low on power when they aren't (they just have a lower voltage output) |
ah yes of course...did'nt think of it that way. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15142 Location: Bradford, West Yorkshire
Posted: Fri Feb 03, 2006 11:37 am Post subject: |
it sends a signal to the gps satellites which then transfers this data back to garmin's hq who harvest this data, along with data from all the times you've gone over the speed limit or driven to the local brothel, and your file just grows and grows.
big brother is watching you and sat nav is his latest spy-tool.
MaFt |
Lester_Burnham Frequent Visitor
Posted: Fri Feb 03, 2006 12:05 pm Post subject: |
MaFt wrote: | alan_t wrote: | so what difference does it make in the settings to choose one battery type or the other? |
MaFt |
Think about it for a second, though - if you were some big, evil meglomaniac organisation - how would you achieve that...
Introducing gadgets that know your exact position, that people would take everywhere, and could magically "beam" that info somewhere ;-), and sell them for an easily afforable price...
Not that I'm paranoid - oh, no.
Think about, it, though - eh, um - <Walter Sobchek> am I wrong? Am I wrong? </Walter Sobchek>
Anyway, I've gotta go now, I need to make a new foil hat, and it's time for my treatment <bzzzt... NO CARRIER |
north_country_boy Occasional Visitor
Posted: Fri Feb 03, 2006 12:51 pm Post subject: |
Beerbellybill999 wrote: | yes fine, but make sure they are high power ie Ni MH 2100 or above |
My hand book says at least 2300mh, what size battery is everyone using here and how long are they lasting? |
Posted: Fri Feb 03, 2006 1:00 pm Post subject: |
Lester_Burnham wrote: | Anyway, I've gotta go now, I need to make a new foil hat, and it's time for my treatment <bzzzt... NO CARRIER |
where do you get your foil hats from? i found a great supplier in ....
tee hee
ps - sorry for digressing... |
Posted: Fri Feb 03, 2006 1:03 pm Post subject: |
MaFt |
20vt-rs Occasional Visitor
Posted: Fri Feb 03, 2006 3:36 pm Post subject: |
Is it safe to keep the batteries in the unit and also have it connected to the ciggy charger from the car? Or doe the batteries need to come out. I have 2300Mah batteries and they last very well, just not had them in and used the charger the same time.... |
Posted: Fri Feb 03, 2006 5:43 pm Post subject: |
the ciggy power supply doesn't actually charge the batteries - it essentially switches batteries off while it's plugged in to external power. shouldn't be a problem leaving batteries in in the short-term, just don't leave them in when if you're not using it for a month or so!
MaFt |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Fri Feb 03, 2006 7:03 pm Post subject: |
Have a look at these AA 2700mAh batteries, not sure how good they are, but the price is good for 8 plus a free case.
HERE |
Nickwolf Regular Visitor
Posted: Fri Feb 03, 2006 7:24 pm Post subject: |
I have been using some 800mAh rechargables and they have been fine for me.
I have the unit connected to the cars supply when in use so the batteries are only for the switch off countdown and a little bit of time when I am loading POI's etc.
I am finding I have to charge them every couple of weeks which is fine by me.
Nick. |
