Pocket GPS World :: View topic - i am virgin help
i am virgin help
eamonn
PostPosted: Mon Dec 05, 2005 11:05 pm    Post subject: i am virgin help Reply with quote
Hello
I have purchased an i3 today
Downloaded poi & speed cams to it
When I use it tomorrow how do i activate to speed cams warning
An idiots step by step guide please
cantgetlost
PostPosted: Mon Dec 05, 2005 11:26 pm    Post subject: Reply with quote
If you have downloaded the database to the i3 it just boings at you as you get close to the cameras, with speed limit in red band at top of screen.
You just have to have unit on and it will warn you!
Fenris
PostPosted: Tue Dec 06, 2005 12:01 am    Post subject: Re: i am virgin help Reply with quote
eamonn wrote:
Hello
That is done automatically provided that you correctly downloaded the POI information and used the Express option in POILoader.
The camera files have a warning distance and speed limit setting, if you are above the speed you will get repetitive alerts when within the warning distance and the POI icon will appear on the screen even when the scale is above that at which POIs are shown. If you are below the speed limit you will get only intermittent alerts.
A quick look at Where To?->Food Hotels and More->Custom Points will show you the categories you have loaded and you can then look at a few to check they are correct, in practice though if you got no errors from POILoader then it should be OK.
Brian
eamonn
PostPosted: Tue Dec 06, 2005 2:06 am    Post subject: Reply with quote
thanks
