Pocket GPS World :: View topic - additional car power lead
phillo79
PostPosted: Mon Oct 17, 2005 8:35 pm    Post subject: additional car power lead Reply with quote
hi all found this on ebay have purcheased one to try but should work no probs
http://cgi.ebay.co.uk/Car-Cigarette-lighter-USB-iPod-shuffle-PPC-Mobile-Phone_W0QQitemZ5819442770QQcategoryZ3293QQrdZ1QQcmdZViewItem
it is a car cig lighter to usb adapter which outputs at 5volts so as an additional lead if you have hardwired the one which comes with the i3 in you use this adapter and your usb cable which comes with the i3 if the link doesn't work search on ebay for car usb theres loads on there
casablanca
PostPosted: Tue Oct 18, 2005 1:51 pm    Post subject: Re: additional car power lead Reply with quote
Then you will need a standard USB to mini USB cable to fit. If you use the supplied Garmin cable it will step down the 5Vdc to 2Vdc
phillo79
PostPosted: Wed Oct 19, 2005 7:26 pm    Post subject: Reply with quote
why would it step down from 5v to 2v when it works from a pc usb port which outputs at 5v surely if this were the case and it did step it down then it wouldn't power from the pc?
