Pocket GPS World :: View topic - BT-308 weak bluetooth signal
sstiefel
PostPosted: Sat Aug 13, 2005 11:15 pm    Post subject: BT-308 weak bluetooth signal Reply with quote
Recently I purchased a bt-308 the only problem that I notice is that the Bluetooth specs say 3-9 meters I am only getting about a foot a way from an Ipaq 1940 and a Ipaq 3975 and a Bluetooth enabled laptop HP nw8000 before losing signal.
I returned the unit once and the replacement is only slightly better gobalsat refused to provide any support even though I purchased it trough an authorized dealer. Does any body have any suggestions or advice.
Steve999
PostPosted: Tue Aug 16, 2005 2:07 pm    Post subject: Reply with quote
Yes - get back on to them again for a replacement or your money back. If it doesn't receive at the specified distance, then it is not fit for purpose.
The common denominator in your case would appear to be the BT receiver. Have you tried using the devices in a different location - may be some interference factor at play if you have tested in just the one location.
I have used a BT-308 for over a year now and it is an excellent unit. However, I have noticed that the BT reception limit is only 6 or 7 feet which fortunately is not a problem for me. I previously had a TomTom BT receiver which would connect from several metres away.
Steve
Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
sstiefel
PostPosted: Sun Aug 28, 2005 5:05 pm    Post subject: Thanks Reply with quote
I found that the unit works best on full chare or plugged in
as long as I have a ful charge im ok Thanks for the help
