Pocket GPS World :: View topic - sd card problem
sd card problem
greg121
PostPosted: Wed Apr 27, 2005 3:08 pm    Post subject: sd card problem Reply with quote
please can someone help??
I have a medion mdpna150 but i accidently re formatted it losing the installation files well everything .
now everytime i turn on it says installationfiles not found in sd/mmc card .then when card is ejected it says application software not installed !please insert SD/MMC card and click ok to install! when doing this it then goes back to the orignal message
Pontyslapper
PostPosted: Wed Apr 27, 2005 9:17 pm    Post subject: Reply with quote
Depending on the version of software you have there are probably at least 2 ways to sort this.
If you are on version 4.4 (1 blue CD, 4 with pictures)
Get the UK/Ireland CD. Copy the directory for UK/Ireland onto the card. Then re-install the software from the Quickinstaller CD - navigate to the directory, and if memory serves, you can pick up the CAB files from there and put them on the card.
On the Medion 256MB card from mine I have the following on there - this card is unused so its exactly out of the box spec...
Card is Formatted for FAT file system, with the name MEDION
Directory - UnitedKingdom Ireland - Contains the maps/DB stuff
File - ignore_my_docs 0KB - Haven't a clue, but it does something
File - Medion.ico 16 x 16 - Medion Icon file
File - Autorun.Inf 1KB - Setup Information File
File - MEDION-Navigator.CAB 5,676KB - Medion Navigator software
Hope this helps. If you need any more help PM me, if you have a different version, hopefully someone else can help.
greg121
PostPosted: Wed Apr 27, 2005 9:19 pm    Post subject: Reply with quote
many thanks works great now cheers
Pontyslapper
PostPosted: Wed Apr 27, 2005 9:22 pm    Post subject: Reply with quote
You never did all that in 2 minutes!!
Either that or the card was playing silly - my old 512MB card, sometimes did if it was cold. Pulling it out and putting it back in after holding it for 30 secs, used to sort it.
Pontyslapper
PostPosted: Wed Apr 27, 2005 9:23 pm    Post subject: Reply with quote
Just realised - I was chuntering on about the PDA not the PNA.
Maybe its the same - don't know. Maybe you could check for others who may run into problems.
22.052 (08 May 24)
