Pocket GPS World :: View topic - TOMTOM GO
TOMTOM GO
user10664
PostPosted: Wed Dec 29, 2004 11:04 am    Post subject: TOMTOM GO Reply with quote
WARNING
JUST TO ADVISE ALL TOMTOM GO USERS AND ALL OTHER PDA USERS
PLEASE NOTE YOU MUST NEVER REMOVE ANY TYPE OF CARD FROM YOUR EQUIPMENT WHEN POWERED UP,YOU SHOULD NEVER CONNECT IT TO YOUR CRADLE WHEN POWERED UP WHEN EVER POSSIBLE ALWAYS
REMOVE IT FROM YOUR CIG LIGHTER FIRST,AND MAKE SURE IT IS SWITCHED OFF.
IF YOU STICK TO THE ABOVE IT WILL PREVENT CARD DATER PROBLEMS
ALSO,POWER DOWN BEFORE YOU PUT IT IN THE CRADLE TO PREVENT
INTERNAL DAMAGE.
HOPE THIS HELPS
MESSAGE LEFT BY RADIO TECHNICIAN EX MARCONI
THANKS JOHN
Old_Phil
PostPosted: Wed Dec 29, 2004 11:32 am    Post subject: Reply with quote
I think I have committed all the sins described in John's warning save pulling out the SD card when switched on.
I have experienced no problems.
PostPosted: Wed Dec 29, 2004 11:42 am    Post subject: Reply with quote
Generally speaking you can insert and eject any kinds of media into media sockets without any ill cause, the only time that you can see a problem is if the card is being written to at the time you eject the card as this can cause damage to the data and create CRC errors, but that's really the only time you'll get any problem.
delboy0754
PostPosted: Wed Dec 29, 2004 1:28 pm    Post subject: Re: TOMTOM GO Reply with quote
johnnyh wrote:
WARNING
INTERNAL DAMAGE.
HOPE THIS HELPS
THANKS JOHN
Utter Rubbish.
I've been connecting and disconnecting while powered since i got mine, and the sd card pulled in and out while changing from one country to another,no problems. As said above, it's only whilst it's writing to the card, can problems occure, and that's while it's connected to a PC.
Plus why are you shouting, turn you cap lock off.
Old_Phil
PostPosted: Wed Dec 29, 2004 6:03 pm    Post subject: Reply with quote
I agree Delboy, but I was trying to be gentle! After all, the only other posting from John says he is not a computer wiz kid and needs help with the speed camera database. But he is an expert in radio and GPS.
I can't imagine why he felt it necessary to broadcast his warning, but I, for one, will be ignoring it.
