Di Occasional Visitor
Posted: Thu Mar 17, 2005 5:49 pm Post subject: Safety camera overlay files |
I have a problem with the overlay files for different camera speeds on TTN3 with h2210 and an SD card. When I unzip the database on the PC, I can see all the different speed overlays being unzipped. However, when it's finished unzipping, I only see one overlay file - as does TomTom. The cameras appear OK on the maps, but I want to separate out the various speed overlay files so that I can set up the appropriate warning messages. The instructions say that you can choose to use either the one combined file or each of the individual speed files - but how do you select to use the individual speed files? Help, please! |
Oldboy Pocket GPS Moderator
Posted: Thu Mar 17, 2005 7:02 pm Post subject: |
You will need to copy the files in the zoned folders, each one has a speed at the end of the file name. There are 7 gatso and 6 mobile sets.
It is possible that you only copied the ONE file in the main folder, it's named Gatso but has no speed reference. _________________ Richard
xda Lifetime Member
Posted: Fri Mar 18, 2005 6:19 am Post subject: |
When you un-pack the complete archive onto the PC you have a separate folder called Speed Zoned. Once you open that there are a further 2 folders called Gatso and Mobile as well as all the .wav files.
if you follow this http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=16308
it will explain where to put all the related files and how to setup CheckPOInt and TT. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Fri Mar 18, 2005 9:17 pm Post subject: Safety camera overlay files |
Thanks to everyone for the advice. I have now solved all problems with a different unzip program and everything now works perfectly. Thanks again. |
