Pocket GPS World :: View topic - Speed Camera Direction
nickpike
PostPosted: Thu Jan 29, 2009 10:45 pm    Post subject: Speed Camera Direction Reply with quote
Hi, I've prepared POI's for speed camera detection, complete with icons and mp3 sounds, and all works well. The original csv files are from PIOplaza, and just give position, although there is a third column with "F50" (for example).
The camera speed is given by adding the number to the csv file, ie, GATSO_20.csv.
Now, the warning operates in either direction, whereas the camera only operates in one direction.
What info is added to the csv file to tell which direction the camera operates?
Cheers,
nick
PostPosted: Thu Jan 29, 2009 11:11 pm    Post subject: Reply with quote
None, Garmin don't support directional information in third party POIs, only their own database offers this.
And good luck with the POIplaza data, much of it has been ripped off from us but is years old and has more holes than a polo mint factory, I wouldn't rely on it were I you.
nickpike
PostPosted: Fri Jan 30, 2009 7:28 pm    Post subject: Reply with quote
Does that mean your database does not give direction?
In the line,
-4.14039 50.39775 S [11144]
Would the 'S' show as a graphic?
What does the [11144] do?
Thanks for any help.
BTW, I'm trying to do my own as the Garmin warnings are so small they are unreadable, especially as to speed. So I'm adding a verbal warning.
nick
PostPosted: Fri Jan 30, 2009 7:30 pm    Post subject: Reply with quote
We have direction data for those systems that support it which are few and far between.
nickpike
PostPosted: Fri Jan 30, 2009 7:45 pm    Post subject: Reply with quote
Also, could someone kindly point me at an SDK or tutorial for writing POIs?
The Garmin help files is lacking.
cheers,
nick
PostPosted: Sun Feb 01, 2009 1:08 am    Post subject: Reply with quote
cheers,
nick
have you read this one?
nickpike
PostPosted: Sun Feb 01, 2009 4:50 am    Post subject: Reply with quote
Yes thanks. It's the same as the help file that comes with POILoaderforWindows_253
cheers.
Does anyone know what bracketed numbers means in the cvs file, inserted after the position columns. And does text in "" show on screen, or what?
PaulB2005
PostPosted: Sun Feb 01, 2009 5:35 pm    Post subject: Reply with quote
The text in brackets usually shows as a banner alert across the screen.
Numbers in brackets? Can you give an example?
inspiredron
PostPosted: Mon Feb 02, 2009 12:42 am    Post subject: Reply with quote
See above ! Rolling Eyes
Isn't it the ID number of the camera in the database?
PaulB2005
PostPosted: Mon Feb 02, 2009 12:49 am    Post subject: Reply with quote
That ID doesn't match to the co-ords....
Nor am i sure where the S comes from...
Which format has this database been downloaded in?
PaulB2005
PostPosted: Mon Feb 02, 2009 12:52 am    Post subject: Reply with quote
I'm used to seeing Garmin data in this format...
;Longitude Latitude Name
-1.54787 49.77304 GATSO:1@40
Data has been edited to change it from the "live" data...
Paddywack
PostPosted: Mon Feb 02, 2009 10:47 am    Post subject: Reply with quote
It appears to be ripped off the SCDB website - they use that format to identify a particular speed camera. Their database has a further column with a description which could be as simple as 'S' or a more descriptive entry like 'after Dublin Airport, northbound'.
I last used the SCDB database when I had a Nuvi 300 and from memory only the '11144' displayed.
I can confirm that notification was not directional.
PostPosted: Mon Feb 02, 2009 11:12 am    Post subject: Reply with quote
Not surprising, POIPlaza have ripped of a number of providers including us.
So far all the data our data that they have is very old and out of date. As soon as we detect current data we will ban the source (who is still identifiable).
