Pocket GPS World :: View topic - Problem adding cameras to a GO520
WelshRob
PostPosted: Tue Oct 09, 2007 2:11 pm    Post subject: Problem adding cameras to a GO520 Reply with quote
Having successfully used the database for the last two years, I now have a problem. I have previously used Navigator 5 on a SD card in an Ipaq and copied and pasted the files into the correct folder.
I now have a GO520 and try to do the same thing. The maps are in the GO's memory rather than on an SD card. I have connected up the GO using the docking station and USB. In Windows Explorer the drive is seen but it asks to "insert disk in drive..." Putting in an SD card with some pictures on, it sees the images but not the internal drive in the GO.
What am I doing wrong as I cannot see the folders on the GO's drive??
I did exactly the same on a TT One and it worked perfectly.
Thanks. Confused
PostPosted: Tue Oct 09, 2007 3:56 pm    Post subject: Reply with quote
When you use USB to connect up any of the new models that have both an SD card slot and internal flash memory, the computer SHOULD see them as TWO new drives (or "mass storage devices"). The SD slot is usually the lower letter drive, but it should just see the flash memory in exactly the same way.
If you aren't getting that, I can only suggest you try all the normal things: a reset of the TT, a different USB socket, checking for conflicts in Device Manager etc.
22.054 (22 May 24)
