BAVC10 Lifetime Member
Posted: Thu Mar 02, 2006 11:04 pm Post subject: |
Cbrom
Great application - been waiting for something like this.
Is it possible to also add an option for altering distances where the speeds are either blank (unknown) or set at 0 (eg Variable speed limit GATSOs on the M25, M42) rather than it maintaining the default settings? |
cbrom Occasional Visitor
Posted: Fri Mar 03, 2006 12:23 am Post subject: |
One step ahead of you there.
I've just done some updates the the application.
You can now select multiple files to convert, and there is a 'default' distance for those 'unknown' or 0 mph speeds.
I've also fixed the little typo MaFt spotted!
Anyway uninstall the old version and install the new 1.0.1.
http://cbrom.myby.co.uk/
cbrom _________________ Garmin Nuvi 310T V9 Maps
Author of Garmin GPX Converter : http://gpx.cbrom.co.uk/ |
markjohnson Occasional Visitor
Posted: Fri Mar 03, 2006 12:42 am Post subject: |
Thanks for the update but the download link still points to the old file.
Kind regards,
Mark
PS Well done |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Fri Mar 03, 2006 1:02 am Post subject: |
This is speed guide i made some time ago, just approx distances:
20 MPH
440 FT - 140 M = 15 seconds
590 FT - 190 M = 20 seconds
730 FT - 230 M = 25 seconds
30 MPH
660 FT - 210 M = 15 seconds
880 FT - 280 M = 20 seconds
1100 FT - 350 M = 25 seconds
40 MPH
880 FT - 280 M = 15 seconds
1200 FT - 380 M = 20 seconds
1450 FT - 460 M = 25 seconds
50 MPH
1100 FT - 350 M = 15 seconds
1450 FT - 460 M = 20 seconds
1850 FT - 590 M = 25 seconds
60 MPH
1320 FT - 420 M = 15 seconds
1760 FT - 560 M = 20 seconds
2200 FT - 700 M = 25 seconds
70 MPH
1550 FT - 500 M = 15 seconds
2050 FT - 650 M = 20 seconds
2600 FT - 830 M = 25 seconds
May be of some use when using cbrom's great utility. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15142 Location: Bradford, West Yorkshire
Posted: Fri Mar 03, 2006 9:25 am Post subject: |
Pocketgps wrote: | This is speed guide i made some time ago, just approx distances:
i spent ages working that out yesterday...
cheers anyway!!
and cbrom, itmay not matter about the extra xml bits as i think poiloader converts the file to it's own format anyway...
cheers for the update!
MaFt |
Posted: Fri Mar 03, 2006 10:35 am Post subject: |
The new version downloads and install ok. I've just checked it!
(i renamed the old version anyway so you shouldn't be able to get it)
cbrom. _________________ Garmin Nuvi 310T V9 Maps
Posted: Fri Mar 03, 2006 10:38 am Post subject: |
Great application, many thanks - Mike |
Ericd Lifetime Member
Joined: Dec 23, 2005 Posts: 57 Location: Plymouth Area
Posted: Fri Mar 03, 2006 6:30 pm Post subject: |
Great piece of kit, first time I have been able to get my distances right.
Thankyou,
Ericd |
portman Frequent Visitor
Posted: Sun Mar 05, 2006 1:53 pm Post subject: |
Thanks for the converter. May i suggest you add it to the 'sticky' listings before it gets lost!
I found it useful because it displays the camera listings on easygps in their geographical location on the map, looks like a swarm of bees. You can then find the cameras that, how should i put this, are more active(read 'bongs alot') on your journeys so you can 'amend' their alert speed a little!! |
Posted: Mon Mar 06, 2006 7:01 pm Post subject: |
Cbrom
Thanks for the changes.
As per my earlier post is it possible to separate 0mph and unknown categories. Many of the Gatso cameras on the M25 and M42 are set to 0mph - and I would use a short alert distance for these, whereas there are many unknown speed cameras where a longer distance would be preferable.
A great program though |
Posted: Mon Mar 06, 2006 8:01 pm Post subject: |
BAVC10,
Should be able to do that, i'll include it in the next release. _________________ Garmin Nuvi 310T V9 Maps
Posted: Mon Mar 06, 2006 11:20 pm Post subject: |
Version 1.0.2
Split the 0 mph and unknown into separate distances
Added a 10 mph speed and distance
Added a 'Results' windows showing the converted files
Download from http://gpx.cbrom.co.uk _________________ Garmin Nuvi 310T V9 Maps
gcb Regular Visitor
Posted: Tue Mar 07, 2006 4:08 pm Post subject: |
Excelent work on the Gpx GPS Exchange Waypoints converter and well spotted that the manual overrides will work with GPX files.
I really like the way cbrom's program promisses to make it easy to override the alert distances which is something really new. I'll try using it.
Still worth mentioning though, albiet if now eclipsed, especially if you have access to data in tom tom format
A Gpx format converter already existed, the same format converter some people were using to convert POIs from Tom Tom ov2 format to csv in the first place for the old POI loader. Believe the guy who wrote this is a moderator on PocketGPS world. He uses username Oldie. Seems to be a clever guy.For his POI converter
http://rjdavies.users.btopenworld.com/html/poiconverter.html |
Ash10 Pocket GPS Verifier
Posted: Tue Mar 07, 2006 11:35 pm Post subject: |
If you upload the camera database as GPX format, do you still only get the audio/visual warnings if the trigger speed is exceeded? |
Posted: Tue Mar 07, 2006 11:44 pm Post subject: |
Ash10 wrote: | If you upload the camera database as GPX format, do you still only get the audio/visual warnings if the trigger speed is exceeded? |
Yes, the only difference with a GPX formatted file is the ability to add an alert distance for each POI. _________________ Garmin Nuvi 310T V9 Maps
