Pocket GPS World :: View topic - Ozi 3D tracks "double-up" on 3D view
djenki21
PostPosted: Tue May 10, 2005 11:55 am    Post subject: Ozi 3D tracks "double-up" on 3D view Reply with quote
Using Oziexplorer 3D 1.08 (beta), I have loaded a track onto the 3D map and it appears as two lines. The first line APPEARS to be on the contours of the rendered map, whilst the second one is "hovering" above the contours. If I toggle the "View Tracks" button OFF, then only the contoured track is displayed: the "hovering" one is disabled. By manoeuvring the viewpoint to be directly overhead, the two lines coincide.
Have I missed a configuration property somewhere here? Do others see this behaviour, or perhaps it is just a feature of the latest beta version I'm using?
David J
Sinaisid
PostPosted: Wed Aug 31, 2005 8:05 pm    Post subject: Reply with quote
If you had the track dispayed in OzEx when you created the 3D map it became a permenant feature!!
Create the 3D map without the track visible and then you can toggle on and off :D
