Pocket GPS World :: View topic - Which BT GPS Receiver should I buy? [4 alternatives]
eroglume
PostPosted: Fri Jun 06, 2008 2:16 pm    Post subject: Which BT GPS Receiver should I buy? [4 alternatives] Reply with quote
PPC: Compaq H3970 [WM2003]
Software: NavNGo IGO8
Receivers;
GlobalTop G33 57$
+: bestseller, cheap
-: heavy and big
Qstarz Q818 80$
+: 32h battery,
-: biggest size, company?, heavy, expensive
Freedom 2000 92$
+: very small size, light weight
-: 9h battery, company? , most expensive
Holux M-1200 65$
+: Reliable company, good quality, small size, light weight, bestseller
-: 32ch. 15h battery
Confused Confused
philpugh
PostPosted: Wed Jun 18, 2008 8:32 am    Post subject: Reply with quote
Welcome
As nobody seems to want to answer....
I've not used any of these but I do own a QStarz BT1000 GPS datalogger.
(as well as a Zytec (sp?) 289BT datalogger and TomTomGPS MkII) It comes down to how you are going to use them. If they are primarily for use in a car or other place with power available then it doesn't really matter about the battery life. If you are going to use them away from power source then ones with exchangable batteries may be better. The QStarz BT1000 (and i believe the Q818) use nokia compatible batteries which made it attractive for me as I have several of these around. It does mean that when I am out for a few days I don't have to rely on power being available.
If you do want to use them in a car then (again) the QStarz BT1000 has a very good anti-slip base - stays rock solid on the dash. (It's going to be tested off the west coast of Scotland on-board a yacht in late July). I would expect the Q818 to be similar. My old TomTom GPS MkII was really small but used to slip around like crazy.
Just a final point - I wouldn't call any of the models 'heavy' - it's just that some are heavier (and bulkier) than the others - all would fit into a pocket without any trouble (and probably still work well). In general the bulkier units tend to have larger batteries to extend their life - it's a trade-off you have to make.
Phil
philpugh
PostPosted: Thu Jun 19, 2008 2:36 pm    Post subject: Reply with quote
And just to make your choice more difficult see Darren's review of some RoyalTek devices
Phil
22.053 (15 May 24)
