Maxmus Occasional Visitor
Posted: Fri Sep 01, 2006 9:27 am Post subject: Navman ICN520 |
I downloaded and installed speed camera files yesterday i followed the instructions exactly however it doesn't seem to be working they do nopt show in my poi's either can anyone help |
Posted: Fri Sep 01, 2006 9:48 am Post subject: |
Did you get confirmation that each file had transferred to the device? Did you rename each file? _________________ Tim |
Posted: Fri Sep 01, 2006 9:52 am Post subject: |
Yes and Yes can see the files when "explore" with actisync many thanks for your interest |
Posted: Fri Sep 01, 2006 10:11 am Post subject: |
Have just checked through 1 set wasn't re named it is still called POCKETGP could this be the problem all other 23 were renamed |
Posted: Fri Sep 01, 2006 10:16 am Post subject: |
Not if only one file has that name. Using activesync, where exactly (full path) are the files located on your device? _________________ Tim |
Posted: Fri Sep 01, 2006 10:21 am Post subject: |
\Program Files\Navman\Shackleton\Navman\mypoi |
Posted: Fri Sep 01, 2006 10:31 am Post subject: |
I never knew there was a Shackleton directory, but Navman do have some unexpected ones and the rest of the path looks correct. When you start up the iCN can you look under Preferences\My Data\My POI and tell me if the files show there and if the boxes are ticked? Also, under Preferences\Safety Alerts\Active POI select one of your POIs (assuming they're there) and see if it has ticks in all three boxes.
Just one other thing, when you transferred the files, did you set the visibility slider to Maximum? _________________ Tim |
Posted: Fri Sep 01, 2006 10:38 am Post subject: |
nothing showing in my poi's or safety alerts |
Posted: Fri Sep 01, 2006 10:41 am Post subject: |
Also yes on vis slider |
Posted: Fri Sep 01, 2006 10:46 am Post subject: |
Connect your iCN to your PC and start Navman Desktop and then start POIEditor. Click Device, Manage POI files. Does a list of your POIs appear there? _________________ Tim |
Posted: Fri Sep 01, 2006 11:50 am Post subject: |
yes they seem to all be there |
Posted: Fri Sep 01, 2006 11:56 am Post subject: |
Then I'm afraid I've run out of options. _________________ Tim |
Posted: Fri Sep 01, 2006 12:08 pm Post subject: |
Thanks for all your help will have a crack at deleting all and starting from scratch |
Posted: Fri Sep 01, 2006 12:12 pm Post subject: |
As a final blind attempt i copied all to "storage card my poi's" and seems to have worked !!!!! Thanks again for your help :P |
