Pocket GPS World :: View topic - Becker MAP PILOT Europa 2018 V16[Q2/2017] Maps & Danger
gavla
PostPosted: Wed Feb 14, 2018 6:09 pm    Post subject: Becker MAP PILOT Europa 2018 V16[Q2/2017] Maps & Danger Reply with quote
Becker MAP PILOT Europa 2018 V16.0 [Q2/2017]! Maps & Danger Spots Europe September 2017
including Becker MAP PILOT Software + hazardous points-Warner Europe September 2017
So this is the second time I’ve released a set of maps so please bear with me, I’ve tested on an M054 device and works but think it may also work on these models:
M054, M075, M076, M083, M084, M085, M092 & M097 but you will have to test for your self.
It does work slightly different from previous modded versions I’ve downloading in the past so read the instructions carefully.
Instructions:
1. VERY IMPROTANT… back you all the files on the root of your device before you do anything (i.e. drag and drop all the files inside “Becker MP” drive to a safe location on your computer).
2. Once the back up is complete delete all the files from the becker device and empty your trash bin
3. Extract all the .rar files make device.xmlt readonly or lock the file if using a Mac (They were readonly or locked but winrar removed this on compression.) and copy the extracted files onto the becker device without altering any other files.
4. Plug into your car and the maps should work.
Now the problem previously came if you plug your becker back into the content manager it would not work back in your car until you copy and replace these 2 files on the becker from the download archive but this may now be fixed but post in the comments if not:
device.xml and device.xmlt Make device.xmlt readonly or lock the file if using a Mac. (They were readonly but winrar removed this on compression.)
then you can use in the car again or you can restore the device by restoring all the files you backed up earlier.
The links will take you to an advert first just wait 5 seconds and hit "skip ad" in the top right corner of the screen.
Download Link:
Rapid Gator Becker Map Pilot V16 part 1 - 10 Apologies for 10 .rar parts but theres a 500MB size limit.
If your thinking of joining RapidGator you can use this referral link for money off.
As requested Uploaded.net Becker Map Pilot V16 part 1 - 12
If your thinking of joining Uploaded.net you can use this referral link for money off.
Sorry about the ads chaps, I had to finance this from my own pocket. Please don't re-host guys, I'm not trying to make money but only cover costs with adfly adverts.
And I almost forgot the archive password is bmpv16 (case sensitive). Thanks Smile
Previous Update 1 to add new info:
Also thanks to testing by valandil314 on his 9077 he got it to work on his 9077 (i assume also M013, M041, M045, M046, M050 und M051, but not sure).
Here is his post with the process he used for earlier becker models:
valandil314;325992]Well, i made this works on 9077 (i assume also M013, M041, M045, M046, M050 and M051).
With the old V14 2016-2017 files, i copy APD folder (except navcore.apd file on apd/software), MapRegionsPSF50 and licences folder (/navi/licenses), and the files AutoRun.exe and the 4 device files (device.sig, device.xml, device.xmlt, DeviceInfo.xml).
I also copy the files of CLM folder and copy to the root (because the gps create those files when plug in into the car).
When i plug in the gps into the car, it says maps are valid and it load fine, i also check the map version in the car and it says Q4/2016.
Sorry for my bad english jaja
Update 2...
We now have 2 conformations that valandil314 method works on these 2 older device models 9077 & M013 so an educated guess would be that his method for these older device will work on these models 9077, M013, M041, M045, M046, M050 and M051
andrewcole
PostPosted: Sun Jun 17, 2018 10:40 am    Post subject: Becker Map Pilot on 9077 Reply with quote
Hi. Thanks for posting this item. I have it almost working on a 9077. I followed valandil314 instructions and the maps are all working fine. However the danger spots don't seem to be working even though I have enabled them in the settings. Any Ideas?
22.053 (15 May 24)
