wakaday Lifetime Member
Posted: Sat Jun 19, 2004 4:32 pm Post subject: IPAQ 2210 ISSUES |
I'm running an IPAQ 2210 v1.1 with TT3. I've had a few annoying problems with the kit. The unit has perfomed a factory reset for no reason twice in the last few months, the clock resets itself. With TT3 the volume turns itself off. The back light illumination turns itself to min with the external power connected. Why does the equipment do this or does it have a mine of it's own. Any comments appretiated. |
Whitebeam Occasional Visitor
Posted: Sat Jun 19, 2004 5:49 pm Post subject: |
Until someone a bit more knowledgeable comes along .....
Factory resets.
Check that your battery is mounted properly and the connections are clean. You can take the battery out to check (unit should run on the internal battery for a while). Do you know the battery(s) state when this happened? Other possibility is a hardware fault.
TT3 volume. Does the volume go to zero / become unchecked (file / properties / navigation) or is there no sound? If the later, are you in navigation mode when this (doesn't) happen? (voice instructions only work in nav mode).
Backlight. there are two backlight settings - battery & external power.
Go to : settings / system / backlight / brightness.
Hope this helps. |
alix776 Pocket GPS Moderator
Posted: Sat Jun 19, 2004 6:08 pm Post subject: |
tis sounds more like an ipaq probblem than a tomtom one try the installing the lastest rom for the hp site but do a full back up before you do install the new rom _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sat Jun 19, 2004 6:55 pm Post subject: |
I understand how to set power mgt, time, tt voice commands. The problem is that my settings change by themseleves.
I'm running the latest HP ROM v1.1. |
rampantrabbit Occasional Visitor
Joined: May 27, 2004 Posts: 17 Location: Fareham,Hampshire, England
Posted: Sat Jun 19, 2004 9:12 pm Post subject: Re: IPAQ 2210 ISSUES |
wakaday wrote: | I'm running an IPAQ 2210 v1.1 with TT3. I've had a few annoying problems with the kit. The unit has perfomed a factory reset for no reason twice in the last few months, the clock resets itself. With TT3 the volume turns itself off. The back light illumination turns itself to min with the external power connected. Why does the equipment do this or does it have a mine of it's own. Any comments appretiated. |
I also have TT3 on an Ipaq 2210, it does not suffer with factory resets but it does keep unchecking the sound within TT3 without any reason. once i re-enable it it will run for a while.
Rab _________________ Ipaq 2210, TTM 3 wired GPS, 256mb CF & TTM 3 Car Kit |
Fraserp Lifetime Member
Joined: Jun 15, 2004 Posts: 297 Location: Manchester, UK
Posted: Sat Jun 19, 2004 9:53 pm Post subject: |
There appear to be several reported incidents of TomTom loosing or changing its properties settings for no apparent reason. i certainly have had this happen several times.
If it happens, dont forget to log it with TomTom support.
The only people who will fix it are TomTom. _________________ Fraserp
TomTom 1000
GPSmap 60CSx
SatMap
iancjc Frequent Visitor
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Sat Jun 19, 2004 9:58 pm Post subject: |
the problem for tomtom is that for people like me TTN3 on a 2210 runs very well (problems with the app/map/traffic excluded). I get no lockups no bt problems and no dropouts.
I think that the 2210 is probably the most popular current ipaq and therefore shows the most problems _________________ -----------------------------------------------------------
TTN6.03 tomtom 7.xx (one) |
