Pocket GPS World :: View topic - Old PDA, New Tricks? is it possible?
uk_martin
PostPosted: Sat Oct 18, 2008 11:18 am    Post subject: Old PDA, New Tricks? is it possible? Reply with quote
I've just been given an O2 XDAII and would like to know if TomTom or something similar can be installed on it.
I have 2 Bluetooth receivers and both pair up OK
I tried to install a version of TomTom (6.02 I think) but the software couldn't connect to the GPS device. Typically it would "hang" at the point where I was allocating a COM port (any of them, I tried the lot) and then for some reason it would reboot itself.
SO...I looked into it all a bit further.
I am led to believe that there should be a GPS Control Panel, which I can't find. I've even installed a Registry Editor (which I'm comfortable about using) and where the Registry was supposed to show that the GPS Control Panel was hidden (for me to change to "show") there was nothing.
Is this device compatible with GPS at all or is it all from a bygone era and I shouldn't be holding out any hopes?
Martin
alix776
PostPosted: Sat Oct 18, 2008 11:40 am    Post subject: Reply with quote
there isnt a gps pannel on the pda OS
go to the setup screen in tomtom then select other wired gps select com5 i think it is from memory and then select a baud rate of 38400
this should work provided you have a legitimate version of nav 6
you could use other application such as direction navigastor 8
or coplilot 7 which should run ok that machine also
device Lumia 950 xl
uk_martin
PostPosted: Sat Oct 18, 2008 2:06 pm    Post subject: Reply with quote
Hi Alix
Thanks for the reply
My "Wired" doesn't give me a baud rate option, nor after a little "hang" does it offer up any COM Port options. As a matter of interest, for the "Other NMEA Receiver" my COM options are:
Infrared Port
BT on COM6
Serial Cable on COM1
COM9
COM2
Serial on USB
So no COM5 even if I wanted it.
But thanks for responding anyway...
Martin
PostPosted: Sat Oct 18, 2008 2:10 pm    Post subject: Reply with quote
What OS have you got running on the XDA is it WM2003SE or have you or someone else flashed it to run WM2005 or even newer? - Mike
uk_martin
PostPosted: Sat Oct 18, 2008 2:47 pm    Post subject: Reply with quote
It's PocketPC 4.20.1081 (Build 13100)
uk_martin
PostPosted: Mon Oct 20, 2008 9:31 pm    Post subject: Reply with quote
uk_martin wrote:
That seems to have scared everyone away. Shocked
PostPosted: Mon Oct 20, 2008 9:48 pm    Post subject: Reply with quote
Its not that easy to scare us....
First off have a read of the first post in This Thread by Lutz which will explain your problem.
Next go to This web site to download the necessary files to sort the problem out on your unit (I hope) - Mike
uk_martin
PostPosted: Tue Oct 21, 2008 12:07 am    Post subject: Reply with quote
Hi Mike
Thanks for the reply. The advice and links you gave ended up in the problem being solved. Fantastic!
Martin
PostPosted: Tue Oct 21, 2008 8:23 am    Post subject: Reply with quote
Thumbs Up Glad to hear it is working, but I should apologise for not offering that advice earlier - it was only when I re-read the thread that the penny dropped! - Mike
