Pocket GPS World :: View topic - New to Sat Map
New to Sat Map
Mubbs
PostPosted: Fri May 30, 2008 7:47 am    Post subject: New to Sat Map Reply with quote
I have just picked up my sat map and had a little play, I can't seem to change from North up to Track up followed Instructions seems very simple but can't change. Could someone help.
PostPosted: Fri May 30, 2008 8:26 am    Post subject: Reply with quote
Welcome to the forum.
Firstly have you got Advanced Power control set to Advanced, if so change it to normal as this power save feature disables the Track up mode to conserve power. Go to Setings and select the second item in the list.
Make sure you have a GPS position fix and you are moving. Get the display to show your position on the map and set of walking, you can toggle between North Up and Track Up modes with the button to the left of the joystick. - Mike
Mubbs
PostPosted: Fri May 30, 2008 8:36 am    Post subject: Reply with quote
Thanks Mike so simple when you know how.
Regards Mubbs
22.055 (29 May 24)
