arsenal_sting Occasional Visitor
Posted: Fri Sep 14, 2007 7:27 am Post subject: Fortuna Clip On help |
have just bought a Fortuna clip on device second hand. Have tried to connect via bluetooth to my ipaq pda and keep being asked for a passkey before the bluetooth connection will work.
where do i get this passkey ?? |
Posted: Fri Sep 14, 2007 7:34 am Post subject: |
0000 (four zeros) is the usuall code to get Bluetooth devices to pair - Mike |
Posted: Sat Sep 15, 2007 12:03 pm Post subject: |
Ok, that works fine and i have the two units connecting using a Pocket A to Z application on the PDA.
But When trying to interface with memory map i cannot get the pocket pc to interface with the gps.
In GPS set up i have set;
manufacturer - NMEA
model - NMEA 0183 (this is a default with NMEA)
port - COM5: Bluetooth Serial Port
baud-4800
but the gps will not work, any idea.
cheers |
Posted: Sat Sep 15, 2007 1:26 pm Post subject: |
Is your Fortuna Clip on one of These ? - if so try setting the Baud rate to 38400 in the Memory Map application, as this is what the device uses - Mike |
Posted: Sat Sep 15, 2007 2:48 pm Post subject: |
Tried that previously as i noted from the Fortuna Clip On review which you attached a link for that the baud rate is 38400.
still not working |
twinpig Occasional Visitor
Posted: Mon May 19, 2008 12:08 pm Post subject: Fortuna with Memory Map |
Hi All,
I've recently installed Memory Map on my iPaq4700, but am having the same problem as above. I've tried every combination of manufacturers & Baud rates possible but still no joy (Fortuna BT Clip on). The GPS instructions say: SiRF Chipset at 38400 Baud rate, & the bluetooth mgr says the comports are 5-incoming & 8-outgoing.
Does anybody have a solution? It's driving me insane!
I've read that there may be a conflict with Tom Tom software, so I uninstalled that, but it still won't work in Memory Map!
Please Help!!! ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
