Pocket GPS World :: View topic - can i make my UK tt one in to europe ??
waynedance
PostPosted: Thu Jan 18, 2007 11:03 pm    Post subject: can i make my UK tt one in to europe ?? Reply with quote
is it just a case of adding the europe map folder and deleting the uk one?
are the units the same?
cheers.
sgould
PostPosted: Thu Jan 18, 2007 11:11 pm    Post subject: Reply with quote
I think the units are the same, but if you download a Europe map, you will need a bigger SD card - at least 1GB.
So keep the original UK map and card in a safe place after you have copied it to your PC as a backup. You can copy the PC backup to the new card to get all the system software installed and then delete the UK map from the new SD card before loading on the downloaded Europe map.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
waynedance
PostPosted: Thu Jan 18, 2007 11:16 pm    Post subject: Reply with quote
cheers, i have a 1gb card in there now.
is that all i need (replace map folder), postcodes will still work and all the camera poi's?
thank you.
waynedance
PostPosted: Thu Jan 18, 2007 11:31 pm    Post subject: Reply with quote
do all sd cards work in the TT.
i have put a 1gb ultra2 card in and it says no maps found?
Scoobydooby
PostPosted: Fri Jan 19, 2007 1:00 am    Post subject: Reply with quote
I have a Sandisk Ultra 2 with my USA maps on it, works a treat.
Are you sure that your Sandisk card is a genuine one? unfortunately there are a lot of wannabee cards on auction sites.
Scoobs
Tom Tom Go 510 (new model)
I'd be lost without it !!
waynedance
PostPosted: Fri Jan 19, 2007 1:17 am    Post subject: Reply with quote
i got it to work, cheers.
going to try out the europe map folder tomorrow.
is there any other folder that needs removing apart from the uk map when i put the europe map folder on?
PostPosted: Fri Jan 19, 2007 2:43 am    Post subject: Reply with quote
Funny... usually when you buy the European map the installer sorts all this out for you.
thebinman
Banned
PostPosted: Fri Jan 19, 2007 9:57 am    Post subject: Reply with quote
Just the map folder (remember to copy your favourites across to your new map).
