Pocket GPS World :: View topic - Help I3 map/gps problems :(
jase1985
PostPosted: Fri Dec 22, 2006 2:22 pm    Post subject: Help I3 map/gps problems :( Reply with quote
hi i got a garmin i3 unit and on the "view map mode" the map doesnt update its self, ie it doesnt show you your current location, eg if i set off at point 1, i drive 1mile down the road, the garmin will still show im at point 1, rather than where i am now, it takes ages for it to update current location.....
the bar along the top knows exactly where i am, its just the screen isnt updating the map
BUT its all fine in Navigation mode, the map moves when i move, its very strange, i rang garmin and they advised me to do a master reset i did upgrade from 2.7 to 3.2 but my friend is going to downgrade the software for me see if it helps
zogman
PostPosted: Fri Dec 22, 2006 2:33 pm    Post subject: Reply with quote
you'll find that going back to firmware v2.7 will solve the problem...let us know how you get on..
jase1985
PostPosted: Fri Dec 22, 2006 3:05 pm    Post subject: Reply with quote
i dnt use my I3 very often as i rarely go out of town, but i recently had POI loaded after the 3.2 so could it be the amount of POI that is causing it too? lso when i press the 3 buttons when unit is out, will it reset back to 2.7? or do i need to do it via PC
philai3
PostPosted: Fri Dec 22, 2006 3:28 pm    Post subject: Reply with quote
You need to do it via the PC. Download the executable from the links earlier in this forum, and run it. It will downgrade you from 3.2 to 2.7. I have done this up and down a couple of times, but have settled on 2.7. Since doing this I have much reduced numbers of lock-ups. I wouldn't say they have been totally eliminated, though, just much rarer.
Garmin I3 October 2006
Garmin 1310 December 2009
(Firmware 3.2-2.7-3.4-2.7)
Renault Scenic with inbuilt Carminat Tom-Tom April 2013
Renault Clio
Mazda MX5 2010
jase1985
PostPosted: Tue Dec 26, 2006 3:42 am    Post subject: Reply with quote
i have gone back to 2.7, its a little better, but still lags, could it be the POI
Wildie
PostPosted: Wed Dec 27, 2006 3:01 pm    Post subject: Reply with quote
been testing this out for months now and the only thing i can see what making it happen is the signal strenght, when i get full signal in map mode it tracks fine, when it drops 1 bar then the fun begins.
just check the signal bars when it starts to lag in map mode.
tom tom start 25
Waze
