Pocket GPS World :: View topic - Lack of alerts
Lack of alerts
Curley52
PostPosted: Mon Oct 23, 2006 8:04 pm    Post subject: Lack of alerts Reply with quote
Hope someone can help. I've loaded the data to a Garmin I3 and it has the camera data in the Custom Points section of the i3 and has the Proximity Alerts switched on but I'm not getting any warning beeps or visible screen warning. The unit is working exactly as it was before i.e. just a sat nav.
Any ideas please?
JockTamsonsBairn
PostPosted: Mon Oct 23, 2006 11:54 pm    Post subject: Re: Lack of alerts Reply with quote
Any ideas please?
I don't have a Garmin, so I'm working from memory here, but I think that you only get a warning if you are speeding?
Jock
PostPosted: Tue Oct 24, 2006 12:05 am    Post subject: Reply with quote
Which camera database have you installed to the i3 ? also can you report back which version of POILoader you have used to install the POI's to the i3.
I am running firmware 2,7 on my i3 and I get an alert when I am within proximity of a camera irrspective of speed, if I am over the speed set by the database I get additional warnings.
Please report back what versions you are using then we can assist further - Mike
Curley52
PostPosted: Tue Oct 24, 2006 10:57 am    Post subject: Lack of Alerts Reply with quote
Having slept on it, I found the problem!
What I'd done was to load the software using the Express method (the Garmin POI Loader recommended option). Unfortunately when using this method the alert default speed and distance options are set to zero, hence no alerts. When I used the Manual method there is an option to adjust the defaults.
Wouldn't it be an idea to set the automatic defaults to something other than zero?
Thanks anyway for the offer of help, very kind of you.
Peter.
PaulB2005
PostPosted: Wed Oct 25, 2006 10:03 am    Post subject: Reply with quote
Never experienced that!!! Express always worked fine for me without tinkering.....
Anita
PostPosted: Wed Oct 25, 2006 3:21 pm    Post subject: Reply with quote
Me too!
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
Curley52
PostPosted: Wed Oct 25, 2006 4:09 pm    Post subject: Reply with quote
Well I was puzzled and it took me a lot of time to find the problem, maybe it was something I did or didn't do.
When I used Express it didn't automatically give me the option of changing the alert speeds or distance and I'm guessing that they were both set to zero. The Manual method automatically comes up with a box to give the option to set the speed/distance (the numbers in the box being set at zero until you change them).
Just out of interest, when you used Express did you use the single speed camera file for the UK?
I loaded the single file covering all speed limits so didn't use the speed option but set the distance to 0.5 mile.
Anyway it works now, good system isn't it.
PaulB2005
PostPosted: Wed Oct 25, 2006 5:32 pm    Post subject: Reply with quote
I don't use the same files as you but the Express Mode isn't suppossed to ask for distances etc - that's the point of the express mode. Not sure why yours sets it all to Zero though....
bunch92
PostPosted: Fri Oct 27, 2006 4:16 pm    Post subject: Reply with quote
I thk you are supposed to use the express mode, not the manual mode.
If you look at the CVS file, you will see that every single camera has a different speed limit (@30 , @60 , etc ...). If you use manual mode and set speed to lets say 30mph, every single camera will have a speed limit set at 30, which is wrong.
My advice is to reload the whole lot using express mode, and make sure the alert mode is ON in the GPS menu.
22.055 (29 May 24)
