Pocket GPS World :: View topic - Differences in TomTom Versions ? eg 5.45 to 6.15 - Sticky ?
jblackmore
PostPosted: Tue Aug 22, 2006 2:15 pm    Post subject: Differences in TomTom Versions ? eg 5.45 to 6.15 - Sticky ? Reply with quote
Sorry if this is somewhere as a FAQ, I searched but can't find it.
Please can someone post a list of major version and the differences, so people can decide whether to upgrade or now.
I have upgraded from 5.45 to 6.15 (eventually), and only changes I can see are annoying changes, like selecting POI warning bounces you back to map, so you have to go back through preferences/ manage poi / poi warnings to set the next category, whereas before you could just select the next poi type and go straight in.
Compass direction and distance seems to have lost distance (which I liked)
Find poi requires you to enter range (3M, 15M etc etc?) before you can see list.
Only useful change I have found so far is you can search all types of POI's which is good for petrol stations etc if you have them listed seperately.
A sticky list of major versions with differences would be really useful.
Currently using TomTom ONE v3 and Live 1005 Camper
TuurG
PostPosted: Wed Aug 23, 2006 10:24 pm    Post subject: Re: Differences in TomTom Versions ? eg 5.45 to 6.15 - Stick Reply with quote
Still works as before for me. It jumps to Manage POIs menu, same as in v5.
still there as in v5: 4 options:
    none,
    arrow north, in compass direction/degrees
    arrow heading, in compass direction/degrees
    arrow destination, , in compass distance
not on mine.
GO1005
MGC GT 1968
MGB Cabrio 1973
Antoeknee
PostPosted: Wed Aug 23, 2006 10:57 pm    Post subject: Reply with quote
To see POI list
navigate to...
point of interest...
POI near you.....
tap the arrow
You will now see the list
jblackmore
PostPosted: Thu Aug 24, 2006 12:03 pm    Post subject: Re: Differences in TomTom Versions ? eg 5.45 to 6.15 - Stick Reply with quote
Is this different on a TomTom ONE ??
If I select a poi warnings on my TomTom ONE, then pick a POI category, and change warning distance for say GATSO camera's, when done I get bounced out to map view, and have to go back in through preferences/manage poi/poi warnings to set the next warning distance (say for mobile cameras) ?
    none,
4th option for Arrow destination on mine doesn't state distance ? And arrow is much larger without distance inside ?
not on mine.
I did this from browse map, search, POI and have to enter range ? Maybe if you start from 'navigate to' it doesn't ask range - will check this.
I will check this again, as sounds like I am going mad - unless the different TT devices all behave differently, and so ONE is different to other units.
I do wonder why TomTom can't provide a 'changes' pdf file to explain the differences, but given there general lack of customer service it seems to be par for the course. I wonder how many support calls they could avoid if they included a manual update with the update !
Maybe if the upgrade is different on every platform, this is why they can't provide a document ?
Dr_Pepper
PostPosted: Thu Aug 24, 2006 2:54 pm    Post subject: Re: Differences in TomTom Versions ? eg 5.45 to 6.15 - Stick Reply with quote
not on my ONE, it goes back to POI manage menu
only if you choose all poi categories
jblackmore
PostPosted: Fri Aug 25, 2006 10:00 am    Post subject: Re: Differences in TomTom Versions ? eg 5.45 to 6.15 - Stick Reply with quote
Tried this again, and think when I was swapping between versions I must have missed a file, as poi warnings now goes back to POI manage screen (before it definately bounced to map).
Distance arrow works too, not sure if this wasn't working before, may have been as I had no GPS lock.
find POIs range is only for all types, as pointed out.
Maybe this confirms the original idea that we should have a list of versions and differences as a sticky on here !!!
TuurG
PostPosted: Sun Aug 27, 2006 3:32 pm    Post subject: Re: Differences in TomTom Versions ? eg 5.45 to 6.15 - Stick Reply with quote
Makes sense,a s it can't caculate distance when it doesn't know where you are Confused
Although you now discover that all still works as before or as expected Question Laughing
Apart from the option to search through all POI categories, there is not much new to explain for the ONE.
GO1005
MGC GT 1968
MGB Cabrio 1973
999tommo
PostPosted: Sun Aug 27, 2006 10:31 pm    Post subject: Reply with quote
TuurG wrote:
none,
On my One with 6.15, the compass preferences are....
"None"
"One with arrow pointing north"
"One with arrow showing your heading"
"One with arrow pointing to your destination"
It does not mention distance anywhere, or am I missing something ?
Tommo...
Regularly absent, but still here in spirit !
TuurG
PostPosted: Sun Aug 27, 2006 11:00 pm    Post subject: Reply with quote
it's not an option to set. If you choose to "One with arrow pointing to your destination" then the distance will be shown in the compass, when you have planned a route AND a gps fix.
GO1005
MGC GT 1968
MGB Cabrio 1973
999tommo
PostPosted: Sun Aug 27, 2006 11:04 pm    Post subject: Reply with quote
Ahh, Got you now. I thought my options were different from yours. Will try to get a fix (indoors) and try it out. Thanks TuurG
Tommo...
jblackmore
PostPosted: Tue Aug 29, 2006 12:54 pm    Post subject: Re: Differences in TomTom Versions ? eg 5.45 to 6.15 - Stick Reply with quote
Quite a few new things.
- navigate to/postcode has moved to navigate to/address/postcode
- compass prefs "One with arrow pointing to your destination" includes distance
- find POI now has several options 'near me', 'near city', 'near home' etc
- find POI now has extra option 'any category' which then prompts for range (<3M, <15M etc) and lists POI's in distance (direct line)
I am sure there are lots of other differences too, which is why a sticky thread seems like it would be useful.
Of course, that depends on what this forum is for, I hoped it was to share info, and a good FAQ would avoid lots of unecessary repeated questions - which we seem to have a lot of on here, as people genuinely can't find basic info easily !
TuurG
PostPosted: Wed Aug 30, 2006 11:06 pm    Post subject: Reply with quote
Arrow to destination has always contained the distance.
But this is what you are looking for?
http://www.tomtom.com/support/index.php?Language=1&FID=5327
GO1005
MGC GT 1968
MGB Cabrio 1973
22.055 (29 May 24)
