stuartgreenwood Occasional Visitor
Posted: Tue Jul 18, 2006 9:53 pm Post subject: unknown file format |
i have downloaded the pgpsw-speedc file from the site but when i open poi editor on smartst and try to open the file i get :unknown file format.can anybody help please: navman icn530.stuart |
Tim Buxton Pocket GPS Moderator
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Tue Jul 18, 2006 10:05 pm Post subject: |
Yes, unzip the downloaded file fully before attempting to import it into the POIEditor. Navigating through the zipfile won't work. _________________ Tim |
Posted: Tue Jul 18, 2006 10:48 pm Post subject: |
hi thanks for that but i am not to good with computers .could you please explain what you mean by that.regards stuart |
Posted: Tue Jul 18, 2006 10:59 pm Post subject: |
If you have Windows XP then use Windows Explorer to find the downloaded zipfile. Double click the file and you should get the option to extract all files. Make a note of where they are extracted to and use those files to import the camera database onto your Navman. _________________ Tim |
Posted: Thu Jul 20, 2006 1:26 am Post subject: |
still having problems finding the zip files. |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Thu Jul 20, 2006 7:08 am Post subject: |
Where are you having trouble finding the zip Files? On the Website or on your PC? _________________ Richard
Andy_P Pocket GPS Moderator
Posted: Thu Jul 20, 2006 11:34 am Post subject: |
If you can say what vesion of Windows (XP, 2000, ME etc.) you are using, someone will be able to provide a step-by-step procedure for that OS. |
Posted: Thu Jul 20, 2006 10:06 pm Post subject: |
i am using windows xp and idownloaded the file into the temp folder.but i still get unknow file format when i follow the instructions. regards stuart |
Posted: Thu Jul 20, 2006 10:40 pm Post subject: |
stuartgreenwood wrote: | .but i still get unknow file format when i follow the instructions. | What is the File Name? If you can't see an extension go to Windows Explorer | Folder Options | View and UN-tick the Option to Hide Extensions for Known File Types.
If there is still no extension on the File, add .zip to the Filename. Double Clicking the File should then Open the Zip Utility associated with Zip Files. _________________ Richard
Posted: Thu Jul 20, 2006 11:02 pm Post subject: |
In even more detail (I was still typing while oldboy answered, but I'm not going to waste all that research :D ...
First open up Windows Explorer or My Computer and go to the Tools Menu. Click on Folder Options and then the View tab. Look in the box and make sure "Show hidden files and folders" is selected and immediately below it "Hide extensions for known file types is NOT selected. (This step is just to make sure your file is actually called what it should be...)
Next, find the file you downloaded (in the Temp directory you say). Check it is called "pgpsw-speed-cams.zip", not "pgpsw-speed-cams" or "pgpsw-speed-cams.zip.zip". If it is wrong, right click on it and rename it correctly.
Assuming it is named correctly, it should have an icon picture that looks like a yellow folder with a zip on it.
If you double-click on it, the window should change and you get a pane on the left wit a box called "Folder Tasks" and below that "Extract all files. (If you DON'T get that window for some reason, you can right-click on on the file instead. You should get a list of optionsand "Extract all" is the fourth one down.
Whichever of those you use, you should now get a new window popping up that says "Welcome to the compressed (zipped) folders extraction wizard". Click "Next", then without changing anything in the next window, click "Next" again. It should now announce "extraction complete", check the box called "show extracted files is ticked and then click on "Finish".
It should now open a new Explorer window showing the location of the actual files, which you can copy to your Go map folder as per the instructions.
If the above doesn't work, I can only guess the download didn't work and the zip archive is corrupted. Download it again and start from scratch. |
Posted: Thu Jul 20, 2006 11:05 pm Post subject: |
Ignore reference to the "Go map folder" above. I meant to re-edit that bit but got side-tracked by oldboy sneaking his post in! |
Posted: Fri Jul 21, 2006 7:21 am Post subject: |
Andy_P2002 wrote: | but got side-tracked | It happens to the best of us. 8) _________________ Richard
Posted: Fri Jul 21, 2006 10:24 pm Post subject: |
But you ALWAYS pip me to the post, oldboy! ![First](modules/Forums/images/smiles/eclipsee_gold_cup.gif) |
Posted: Fri Jul 21, 2006 10:39 pm Post subject: |
Andy_P2002 wrote: | But you ALWAYS pip me to the post, oldboy! ![First](modules/Forums/images/smiles/eclipsee_gold_cup.gif) | Win some, lose some.![Not Worthy](modules/Forums/images/smiles/11.gif) _________________ Richard
