Pocket GPS World :: View topic - TomTom 5.21 & POI Capture
Pirate77
PostPosted: Fri Dec 02, 2005 12:56 pm    Post subject: TomTom 5.21 & POI Capture Reply with quote
Ahoy there!
OK. I have TT 5.0 Navigator installed on my Yakumo Delta 300 PDA (Mio 168 variant) all of which I purchased via eBay a while ago. It would appear that I have a . . erm . . 'backup' copy of TT 5.0, so no serial numbers etc. It's installed onto the SD card. Fine, no problems, works well. Clearly, I am not alone in this department, so please, no sarcastic comments.
I would like to install the POI capture programme, but cannot do so unless TT 5.21 is installed. I have dowloaded both the .exe and .zip options of TT 5.21, but am unable to install it without serial numbers or whatever relative to the GB Plus map!
Does some bright spark out there know of a method/solution to update to the latest version of TT 5.21 in order to allow me to install the POI capture facility, i.e, move specific files over from the 5.21 update directly into the relevant folders on my SD card Question
Pirate!
BodgerBaz
PostPosted: Fri Dec 02, 2005 4:12 pm    Post subject: Reply with quote
Well shiver me timbers if you don't have a problem there. I've scratched me wooden leg with my hook and can only offer the following advice.
Either buy a legit copy of Tom Tom and you can happily update to any newer version in the future (this will also give you the choice of ordinary maps or the enhanced plus maps).
The other solution is to go back to ebay where I'm sure there will be a newer 'backup' copy available soon.
Now set sail shipmate coz I hear the press gang approaching . . . .
MarkHewitt
PostPosted: Fri Dec 02, 2005 4:49 pm    Post subject: Re: TomTom 5.21 & POI Capture Reply with quote
It's easy BUY THE SOFTWARE. Hope that helps :D
Pirate77
PostPosted: Fri Dec 02, 2005 5:07 pm    Post subject: Reply with quote
I knew this would happen!
Pirate!
alix776
PostPosted: Fri Dec 02, 2005 6:20 pm    Post subject: Reply with quote
hi pirate I'm afarid they other guys are right if you need an activation code when you down load and update from tomtòm then you need to get a legit version sorry
device Lumia 950 xl
Pirate77
PostPosted: Wed Dec 07, 2005 1:17 am    Post subject: Reply with quote
All is good. A solution has been found. Ha harr Exclamation
Pirate!
madaxeman
PostPosted: Sat Aug 12, 2006 9:46 am    Post subject: Reply with quote
Hello
Does anyone know whether POI Capture will run along side POI Warner and TomTom 5.21 ?
I have tried installing POI capture but have had no success in getting it to work Confused
I use a Mio 350P ppc
Madaxeman
