Pocket GPS World :: View topic - TomTom and GPS
TomTom and GPS
blueyzfr1
PostPosted: Sat Jun 24, 2006 1:46 pm    Post subject: TomTom and GPS Reply with quote
Hiya,
I have a TomTom GPS system. is it compatible with Autoroute 2006?
If so how do I connect as scan finds nothing :-(
Cheers.
PostPosted: Sat Jun 24, 2006 1:48 pm    Post subject: Reply with quote
It should work, is the GPS unit wired or Bluetooth? - Mike
peterc10
PostPosted: Sat Jun 24, 2006 5:34 pm    Post subject: Reply with quote
What do you mean by compatable? What are you trying to achieve?
Peter
HTC Sensation
Copilot for USA
JockTamsonsBairn
PostPosted: Sat Jun 24, 2006 8:06 pm    Post subject: Reply with quote
I think they are being quite literal :-
blueyzfr1 wrote:
I have a TomTom GPS
and are trying to use it as the GPS receiver for Autoroute.
It should be possible presuming that there is a bluetooth system on the PC.
Jock
blueyzfr1
PostPosted: Sat Jun 24, 2006 9:03 pm    Post subject: Reply with quote
Yep I have a bluetooth adaptor on the PC which pairs up to the TomTom GPS OK. I thern go to autoroute 2006, select auto detect and it finds nothing :-((
PostPosted: Sat Jun 24, 2006 9:38 pm    Post subject: Reply with quote
Firstly have you added the GPS unit within the Bluetooth application on the PC?
Double click the Bluetooth icon in the task bar, if the GPS isn't listed click the Add button, and follow the wizzard to connect up to your GPS unit.
If the above is working fire up Auto Route and go to Tools/ GPS/ Cofigure GPS Reciever, select scan and the software should find the GPS data, to display present position on the map make sure you go to the Tools/ GPS Task Pane, within this selct the "Track Position" check box to display the icon, the other check boxes are up to you - Mike
blueyzfr1
PostPosted: Sat Jun 24, 2006 10:35 pm    Post subject: Reply with quote
Yep.
Already Done
It does not find it :-(( Is there a bug? or a patch anywhere?
Cheers for the reply BTW :D
MrT
PostPosted: Sun Jun 25, 2006 11:42 am    Post subject: Reply with quote
This may be obvious but you could have overlooked it.
When running from the PC (this will vary) you usually have to connect the PC to the TomTom device as a serial connection on a COM port from the bluetooth software/manager before starting the application. Unlike the PDA, connecting the application to the COM port on the PC does not automatically establish the bluetooth connection to the device.
You allocate the same COM port in Autoroute - Tools - GPS - Configure Receiver. Once you are sure that the PC Bluetooth has an established connection, on my older TT Bluetooth devices this is a steady blue light, you go through the menu in Autoroute, Tools-GPS-Start GPS tracking.
blueyzfr1
PostPosted: Wed Jul 05, 2006 8:39 pm    Post subject: Reply with quote
Hiya,
I can pair BlueSoleil and connect with the TomTom GPS using 0000 as the key but I cannot seem to allocate a serial port, says it has run out?????
I'm sure if I can allocate a serial port correctly the bluelight will steady and I am away, any ideas on how to as I am really confused.
Ta!
andrew0401
PostPosted: Sun Oct 08, 2006 10:51 am    Post subject: Reply with quote
Same problem - tying to connect TOMTOM ONE to the lapyop using BlueSoleil - howe do you make it pair - 0000 does nor worl for me
PostPosted: Sun Oct 08, 2006 11:15 am    Post subject: Reply with quote
What are you trying to achieve by connecting the TT One to a laptop using Bluetooth? - the previous poster was trying to connect a Bluetooth GPS unit to a laptop which is a completely different situation - Mike
alix776
PostPosted: Sun Oct 08, 2006 11:17 am    Post subject: Reply with quote
andrew the bluetooth on the tt one will only connect to allow a mobile phone connection to GPRS
device Lumia 950 xl
blueyzfr1
PostPosted: Wed Oct 11, 2006 10:18 pm    Post subject: Reply with quote
I fixed this by ugrading my bluetooth software :D
