Old_salt Occasional Visitor
Joined: May 16, 2006 Posts: 8 Location: Snodland, Kent
Posted: Sun Jun 04, 2006 7:44 pm Post subject: Nuvi loss of satellite signal. |
I have twice lost the satellite signal when I have travelled through the Dartford Tunnel. While I realise the signal will be lost, can anyone explain why my Nuvi does not regain the signals after emerging from the tunnel? I have travelled miles from the tunnel expecting the signals to be active, but they do not. I have cycled powered off/on and the signals returned. Am I missing something or is this normal for the Nuvi? |
Jamas Regular Visitor
Joined: Mar 02, 2006 Posts: 76 Location: Toulouse-France
Posted: Tue Jun 06, 2006 11:24 pm Post subject: Re: Nuvi loss of satellite signal. |
Old_salt wrote: | I have twice lost the satellite signal when I have travelled through the Dartford Tunnel. While I realise the signal will be lost, can anyone explain why my Nuvi does not regain the signals after emerging from the tunnel? I have travelled miles from the tunnel expecting the signals to be active, but they do not. I have cycled powered off/on and the signals returned. Am I missing something or is this normal for the Nuvi? |
It is a known default of the SIRF III chipset also present on the 60CSX handset. The Sirf III firmware has been recently upgraded but it does not fix the "tunnel" problem. Waas/ Egnos disable "may" ease the satellite recovery. (To be confirmed)
Only current solution: stwitch the unit off then on.
New Sirf III firmware upgrade will probably solve the problem.
WARNING: Take care not to use WebUpdater as several Nuvi owners have lost their unit during a software/firmware with WebUpdater with this message:" Software missing".
Do the S/W upgrade manually.
Jamas _________________ SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+ |
Posted: Wed Jun 07, 2006 8:41 am Post subject: |
Thanks Jamus,
I thought my problem was unique to my Nuvi only. Thank you also for your warning of the Webupdater, I had recently used it to update the software and did not encounter any problems. I will heed you warning for future updates however. I will try the Nuvi with Waas / Egnos disabled, as I will be using the Dartford tunnel again at the weekend.
Old_salt |
Posted: Sun Jun 11, 2006 8:00 pm Post subject: |
As I said in my last post, I would give my Nuvi with Waas / Egnos disabled when I wastravelling through the Dartford Tunnel this weekend.
Well I can say that Jamus was correct, and my Nuvi did search for satellite signal when I emerged from the tunnel.
Thank you Jamus for your suggestion
Old_salt |
